ch-viladrich and I had some PM messages and he seeded my mind with an idea
i have an omega caH filter that seemed to wide to get cah detail
it behaved like a baader K line
so
i took out my shg to test
here is my SHG set up and image it can produce (SHG CaH)
my SHG and using it to test some solar filters
- Has thanked: 57 times
- Been thanked: 1189 times
Re: my SHG and using it to test some solar filters
so first i test baadar k line here is what it allows thru
thick lines are the caH and caK lines H on top
this filter is pretty wide
here is test for Omega caH filter
it is not wide band -- that was an error in my part
its off band towards red
look hard caH line is below bright line
so can this be fixed?
if error is not to far away from H line I can tilt filter and bring it back to H line?
so I have skybender tilter and using my caK to visual converter eyepiece
i looked until I see plague area light up
here is results tilt worked (at least to some extent)
tilt and then no tilt
- Been thanked: 8793 times
Wow!! well done! a great bit of investigative work
thx Montana
i had filter for a few years
only now i can use it properly
i think its because omega caK line was correct on K spectral line (no tilt needed) but H was not
so i assumed it was in error
- Been thanked: 10248 times
Always love a problem solve like this
- Been thanked: 2713 times
Well done !
Spectrographs are indeed quite usefull :-)
