My first Hα animation with D = 200 mm (and a flare)
An archive of all the best images Solar Chat has to offer!
GreatAttractor
Has thanked: 747 times
Been thanked: 753 times
Post by GreatAttractor »
On Sunday the seeing was finally good enough to utilize my RC8 + LS50THa + Aried tri-band ERF setup.
One of the best videos yielded this image of AR 2822 (check out this thread if you'd like to play with the raw stack):
I continued recording for some time, even though the seeing was variable and a high thin cloud was passing. I saw a few bright points appear, but had no way of knowing it would be a nice C4.0-class flare, until I put together an animation:
Beside the "igniting grass", note how there's a brightening in the billowing "smoke", right before a thin stream gets sucked back in to the smaller sunspot.
I'm really satisfied; even despite the so-so seeing this tiny thing looks very interesting. Can't wait for an M-class like the one I caught with 90 mm – it would fill the whole FOV with twisting and churning plasma!
I also recorded a CaK animation (Lunt CaK module, 90 mm refractor, PowerMate 2.5x), much better seeing than during the previous attempt, with consistently good resulting frames, but nothing happened there at all:
Mandatory full disc from Lunt 50:
and proms from the 90 mm mod:
My software:
My images
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Re: My first Hα animation with D = 200 mm (and a flare)
Post by Stardust5858 »
Amazing, lovely animation of the flare. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
You captured some amazing dynamics from this activity region.
Beautiful to watch.
Peter
minhlead
Has thanked: 734 times
Been thanked: 1097 times
Post by minhlead »
Amazing!
Minh.
Loves from Viet Nam <3
My gear:
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
Fed
Oh, I get it now!
Oh, I get it now!
Has thanked: 18 times
Been thanked: 23 times
Post by Fed »
Great animation! I was captivated for quite some time watching it.
EGRAY_OBSERVATORY
Been thanked: 4908 times
Post by EGRAY_OBSERVATORY »
Absolutely Fabulous animation and well interesting too. Also the stills are really great.
Thanks for sharing
Has thanked: 17458 times
Been thanked: 16550 times
Post by DeepSolar64 »
I caught this flare visually Sunday using my SMII60. I did not get a view like this though. That's an awesome animation at a considerable magnification.
Has thanked: 8352 times
Been thanked: 8103 times
Post by Carbon60 »
Superb animation. Amazing dynamics beautifully captured.
Ivan
Has thanked: 3461 times
Been thanked: 2250 times
Post by Ivan »
Fantastic video, great luck.
Is this your new mod?
Ivan
MAURITS
Has thanked: 2406 times
Been thanked: 4737 times
Post by MAURITS »
Great work, amazing animation.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
GreatAttractor
Thanks, everyone. Too bad seeing was deteriorating and clouds started rolling in – NOAA says 50 minutes later there was another flare in this AR, also C-class, but over twice as powerful.
Ivan wrote: Thu May 13, 2021 6:25 am Is this your new mod?
Yes, described here.
My software:
My images
Has thanked: 17521 times
Been thanked: 8763 times
Oh my goodness!! this is simply stunning :bow :bow :bow
What an animation :movie
christian viladrich
Has thanked: 1 time
Been thanked: 2702 times
Post by christian viladrich »
This is great !!
Has thanked: 9074 times
Been thanked: 5977 times
Post by ffellah »
A fantastic set, great attractor. The animation is magnificent.
