Mercury sodium tail
- KMH
- Has thanked: 641 times
- Been thanked: 725 times
Mercury sodium tail
You may have read about the recent visibility of Mercury's sodium tail. A number of elements are sputtered off the surface of Mercury by the combination of solar wind and micrometeorites, forming a very low density (non-collisional) atmosphere of sorts. Some of this material is blown away from Mercury by radiation pressure, similar to what happens with a comet. One of the primary components is atomic sodium, which exhibits very strong resonant scattering at 589 nm. However, the sun has a strong Fraunhofer absorption feature at 589 nm due to sodium in the outer atmosphere, so much of the time the Mercury's sodium tail is not very bright. But +/- about 16 days from perihelion Mercury has it's maximum radial velocity with respect to the sun (its orbit is highly eccentric). The resulting Doppler shift increases the wavelength of the photons necessary for sodium scattering to the wings of the absorption feature, so that the intensity of (Doppler shifted) 589 nm radiation at Mercury increases by about 10x relative to perihelion.
We saw some examples of amateur imaging of the tail using narrow-band filters and decided to give it a try - with success! Still working on processing but here is an example from 5/12/21.
80 mm f/6 refractor
Canon 6D DSLR
Edmund optics 589 nm filter with 10 nm bandpass.
Stacked five 30 second exposures.
There is significant vignetting because the filter is only 1" diameter. Also, it is not an image quality filter, which doesn't help! But we were excited to see anything.
NOTE - the tail was predicted in the 1980s but not observed until 2001.
Kevin
80 mm f/6 refractor
Canon 6D DSLR
Kevin
- ps1crop_dfine_dss_v2_mercury_051221_small.jpg (1004.53 KiB) Viewed 1716 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: Mercury sodium tail
Excellent, Kevin. That’s a superb image. I first saw this phenomenon on Spaceweather a few days ago. Fascinating.
- Has thanked: 20424 times
- Been thanked: 10243 times
Interesting!
- JochenM
- Been thanked: 1619 times
- Been thanked: 2713 times
Amazing. Well done !
Thanks for sharing.
Thanks for sharing.
- Has thanked: 9401 times
- Been thanked: 5564 times
WOW
- KMH
Thanks, all. We learned about this on very short notice and were quite lucky to get some shots around the brightness maximum. Hopefully we can try again before too long, maybe having invested in a higher quality filter or even rigging up an occulting disc of some sort.
Here are a couple of links to interesting papers on the subject. The second one (unfortunately behind a pay wall) also shows images of the moon's sodium tail, and also the torus surrounding Jupiter (generated by Io), both with a 100mm scope. Will have to try Jupiter this coming opposition.
Kevin
https://agupubs.onlinelibrary.wiley.com ... 07GL032337
https://link.springer.com/article/10.10 ... 009-9314-y
Kevin
- Has thanked: 17667 times
- Been thanked: 8787 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
I’ll repeat some of the comments above: WOW!
What a terrific, informative post and a fabulous capture.
I had no idea about this phenomenon.
Thanks for enlightening me.
Peter
MODS: Alexandra and Mark, would this be a better fit in the Spectroscopy forum?
Peter
- KMH
Thanks again, everyone!
We will definitely try this again, maybe with a better filter. We also will try to image the sodium/sulfur cloud around Jupiter this opposition.
One question maybe someone here can help with. It might be helpful to use an occulting bar. I have seen explanations of how to do this with an eyepiece but not so much for imaging (at least at an amateur level). One of the links above shows a dedicated 1x assembly of two identical lenses with the mask at the focal point in between. This assembly is the first element in the optical train. Does anyone have any other thoughts on this?
Thanks,
Kevin
Thanks,
Kevin
- Has thanked: 9144 times
- Been thanked: 6025 times
- pedro
- Has thanked: 14 times
- Been thanked: 6576 times
Fantastic Kevin, amazing stuff
Pedro Re'
This is indeed a fantastic topic Peter, it is probably relevant in both forums, so I will add a copy into the spectroscopy forum so you can find it both here and there in the future
- Has thanked: 42 times
- Been thanked: 1487 times
For those with a SHG, I suspect one could image in Na and see this effect quite nicely.
- Been thanked: 6 times
The guess was that this is too faint for eyeball onserving? The original image came from a 66mm refractor, one does wonder what some aperture and maybe additional filtering could do?
Peter
Peter
- KMH
I haven't seen any reports of visual sightings. I did see an image though that was taken without any type of filter. Maybe visual would have been possible with the right equipment???
This was a very favorable occurrence - greatest elongation well-timed with respect to perihelion (Mercury's) and combined with a favorable ecliptic inclination. We might have to wait a couple of years for a repeat.
