PST Tuning Ring
Has thanked: 64 times
Been thanked: 4407 times
PST Tuning Ring
Post by MapleRidge »
Hi All...
My clumsy fingers dropped the little bolt that threads in to lock the tuning ring on the PST etalon and despite searching for over an hour I can't find the little thing in the grass :oops:
Can anyone tell me what the thread size is so I can hunt down a replacement? The smallest machine bolt I have is a 4-40 and it doesn't seem to want to thread in and I don't want to force it.
Thanks for any guidance :bow
thesmiths
Has thanked: 47 times
Been thanked: 1522 times
Re: PST Tuning Ring
Post by thesmiths »
I'm assuming that the etalon is being used in a PST mod?
Re: PST Tuning Ring
I have used it on a mod, but in this case I had re-assembled the PST to its original form and found I had to change the tuning more than the ring would allow. I was just careless and dropped the little bolt that locks the tuning ring in place, and can't find it in the grass. I heard it hit the tripod as it fell and did not see which way it was deflected.
Fabio_Imm
Has thanked: 214 times
Been thanked: 146 times
Re: PST Tuning Ring
Post by Fabio_Imm »
Hello Brian,
As a last resort, you might consider "fishing" the area with a strong magnet.
Fabio
Re: PST Tuning Ring
Hi Fabio...
The magnet was my first try after I couldn't find it in the grass when it first fell. It bounced off the tripod leg and I have no idea which direction it went or distance which makes it more difficult to pin down a search. I am going to look again today and see fi I get lucky!
Thanks,
Has thanked: 174 times
Been thanked: 618 times
Re: PST Tuning Ring
Post by Merlin66 »
Brian,
EDIT: correction. It's obviously a M2.5 screw!!!!
thesmiths
Re: PST Tuning Ring
Post by thesmiths »
I assume it is this screw that you dropped:
pst screw
pst screw
I tested to see if it is even magnetic. With a very strong N42 magnet, it is just barely able to be picked up. I suspect that if it were embeded in grass, a magnet would not be able to catch it.
Here are some measurements. Maybe it's a M2.5 screw?
screw diameter
screw diameter
screw thread
screw thread
The screw just threads into the outside ring. The etalon itself has no threads. In theory, you could drill and tap any size hole. I actually removed the ring entirely and just use a match stick as it allows access to all the little holes and you can have a wider tuning range (since the tuning changes with time due to compression of the spacers inside).
pst match stick mod
pst match stick mod
Re: PST Tuning Ring
Hi Ken...
Yes, that's the one!
I tried with the magnet and found nothing...similar sized bolts I had were not overly attracted to the magnet and the grass would tend to bush it off if it did catch it. I'll take a look for a replacement int he size you suggest, and can keep it working for the time being.
Thanks,
thesmiths
Re: PST Tuning Ring
Post by thesmiths »
To Brian: actually, the photos of the screw came from me, your fellow Canadian (not Ken). I took a look at the specs for M2.5 and the thread seems to approximately match the photo I took (around 0.5/mm). So M2.5 x 10mm Philips flathead countersunk appears to be the likely replacement. Doug
Re: PST Tuning Ring
Sorry about that mix up...what I get for looking on the phone and small screens cut off the full post.
What part of Canada do you call home?
thesmiths
Re: PST Tuning Ring
Post by thesmiths »
To Brian: Montrealer living in London (not the one in Ontario). Doug
