Earth-Sun Scaling tutorial & Images” written by “krakatoa1883
Moderator: marktownley
- Has thanked: 2501 times
- Been thanked: 4924 times
April 14 Evolution ...
A serious evolution between today and yesterday, with a beautiful "arch" forming on this prominence.
ASI 174MM camera with interference eliminator.
Quark Chromosphere
TOA 150-B with Baader DERF.
Quark Chromosphere
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: April 14 Evolution ...
Very good images with much details in the spicule carpet, my Quark Chromo is not so good. Is the interference eliminator needed with the 174 ?
Raf
- banjo
- Has thanked: 2123 times
- Been thanked: 2903 times
superbe, bravooooooo !!!!
Paul
Raf, without de eliminator I have NR's with the 174MM.krakatoa1883 wrote: ↑Wed Apr 14, 2021 3:00 pm Very good images with much details in the spicule carpet, my Quark Chromo is not so good. Is the interference eliminator needed with the 174 ?
- Has thanked: 9379 times
- Been thanked: 6198 times
- Has thanked: 6353 times
- Been thanked: 7407 times
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Great Prom detail Maurits, thanks for sharing your images.
Martin
Martin
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely images Maurits. Thanks for sharing
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 18090 times
- Been thanked: 8934 times
Wow!! this is a gorgeous shot
That is one thing I should learn, how to get an Earth on a picture. The biggest downfall for me is that I have never found a decent Earth picture to use and how you get it so small without it being one big pixel?
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Alexandra,
I think this Earth may be reasonably easy to use. I already isolated the Earth, its 673 pixels. I could explain it to you, but I have plans to make a Solar SSM ! I could publish it another time on the tutorials section.
There is some information on Brierley Hill solar blog, although I found the sound very hard to hear and understand.
https://brierleyhillsolar.blogspot.com/ ... rials.html
I had to learn Photoshop, layers and everything. Still not learned it al! after more than 2 years ! You can also use GIMP or Affinity Photo, which are less expensive alternatives and quite adequate.
I only found it after an extensive search online.
Magnus
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Radon86
Maybe this is easier to see/use.
Alexandra, I have the "TIF image" that I use in my images as above.
You can use them, can I set it up here as a TIF file?
Thanks a million TIFs aren't displayed in the forum but you can right click and open them
- Radon86
Alexandra,
Maybe this is better for you. It has the UK near the centre...
- Radon86
Hi all,
I think I have found an easier way to calculate the size of the earth (in pixels) - this will be an option in your imaging program - to resize the earth image. Assuming the diameter of the earth is 109 times smaller than the sun, and the sun is about 30 minutes of arc = 1800 arc seconds.
Then just calculate your image scale using the calculator in:
astronomy.tools
(make adjustments for your optical train) - once you have this reasonably accurately: then (image scale is in arcseconds/pixel).
size of earth (pixels)= 16.514/(image scale)
This will save you the hassle of having to draw a large circle in photoshop, measure the diameter of the sun in millimetres and dividing it by 109 to get the diameter of the earth.
I am sure this has been done before, but not able to find a reference to it.
If I am wrong, then please correct my error(s).
Hope this helps.
Magnus
astronomy.tools
Hope this helps.
Magnus
Two excellent images Maurits of the prom showing fine detail
Thanks for sharing
Regards
Thanks for sharing
Regards
- Has thanked: 174 times
- Been thanked: 619 times
Here's an Aussie version.....
Placed in Library for reference.
