The weather has been poor over the last week.
Finally found some time to process the video recordings taken on 23 May 21. The object was AR2824 . The imaging jig was a C11 fitted with an ARIES D-ERF (used at full aperture) and a Daystar Quark Chromosphere. Overall I made 37 recordings from 9:30 to 10:05am local time. I made the following animated gif from 33 good recordings:
This was how a typical single frame looked like:
I am happy to see the evolution of the various filaments and fibrils. What other solar features can you make out from the animation?
You can do a right-click to see the gif in full resolution.
Alfred
Hi-Res H-Alpha animated gif on AR2824 (23 May 21)
- yltansg
- Has thanked: 1423 times
- Been thanked: 1386 times
- Has thanked: 9074 times
- Been thanked: 5977 times
Re: Hi-Res H-Alpha animated gif on AR2824 (23 May 21)
Definitely seeing the flaring, Alfred. Lovely animation and stills.
- Has thanked: 17524 times
- Been thanked: 8763 times
Wow!! to get seeing that good for so long is a miracle
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Nice animation, Alfred.
Some spectacular high resolution details in the two images.
Peter
Peter
- yltansg
Re: Hi-Res H-Alpha animated gif on AR2824 (New variant added)
I have added a 150ms delay between frames and make it non loop so that the reader can have better control to see the evolution of various features in the half hour duration:
You can do a right-click to open the gif in a new tab and click on "reload this page" to start the animated gif to see the development of each feature of interest.
Comparing the 2 version, which one do you prefer?
Hope to hear from you.
Thanks.
Alfred
Thanks.
Alfred
- Been thanked: 4883 times
Alfred:
Beautiful work all of it.
- Has thanked: 6161 times
- Been thanked: 7097 times
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Stunning animation in Hi-Res Alfred!
You won against the seeing!
Thanks for sharing,
Alexandros
Thanks for sharing,
Alexandros
Alexandros
Greece
Greece
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Hi Alfred
Cracking animation and HR images
Kind regards
Kind regards
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- Has thanked: 20240 times
- Been thanked: 10113 times
Excellent results Alfred and congrats on the SPOD!
- Has thanked: 8355 times
- Been thanked: 8103 times
Brilliant, Alfred. Lots going on over huge distances in such a short period of time. Very nicely done.
