About a year ago my magnetometer failed and when I checked into the fault I found the buried equipment flooded with water. I made some mods to the housing and installed a new sensor and electronics, but was never really fully satisfied with the final result which was close to, but not exactly matching data generated by professional geomagnetic observatories.
I've since assembled another sensor, built a new circuit and created what I think will be a more watertight housing using a glass jar, lots of melted wax to pot everything and a coating of durable polymer. I've also relocated the sensor in a different part of the garden which I believe will be a drier spot.
Now in its new location and buried about 0.5m in well drained soil I'm hoping for the best. My first full day's results after letting everything re-equilibrate look great. Here's a chart created on the 7th as compared with the professionals using my standard 150 second sampling cadence:
...and here's a magnified view of the region between 6:00 am and 9:00 am in hi-res mode captured at 1s cadence compared with professional data. The red lines illustrate the alignment and close matching of both sets of data.
I think this is about the best performance I've had out of this equipment. Very pleased.
Watch this space as cycle 25 continues to develop.
Thanks for looking.
Magnetometer upgrade 7th June 2021
- Has thanked: 8559 times
- Been thanked: 8290 times
- Been thanked: 2725 times
Re: Magnetometer upgrade 7th June 2021
Marvellous Stu. The accuracy looks quite good !
- Been thanked: 10488 times
Reference grade! Very good Stu!
Wow!! looks like you cracked it as the comparison is remarkable. Looking forward to the data going forward
- Has thanked: 47 times
- Been thanked: 1525 times
That's really good agreement. I assume you could use the "professional" results to calibrate the magnitude and offset.
By the way, would there be any point to a second sensor orthogonal to the first? I would guess where you are the Earth's magnetic field is probably tilted downwards around 45 degrees to the local ground level.
Many thanks, Christian, Mark, Alexandra and Thesmiths.
Looking forward to when the activity builds.
Hi,thesmiths wrote: ↑Thu Jun 10, 2021 3:55 pm That's really good agreement. I assume you could use the "professional" results to calibrate the magnitude and offset.
Three orthogonal sensors are used to measure the magnetic field in full, but only one is required for our purposes.
