Deep Sky images from a Bortles Class 9 white zone
Lets brighten up peoples live with all those lovely pictures of the world around us!
Moderator: Montana
thesmiths
Has thanked: 47 times
Been thanked: 1522 times
Post by thesmiths »
I recently started taking some deep sky images of broadband sources from our location in central London. This is a Bortles class 9 location, a so-called white zone. You would think it would be impossible to take images of dim objects like galaxies when you can barely even see any stars in the sky. But an interesting technique that I learned about recently allows taking broadband images (rather than narrowband images like H-alpha) from the most extremely light polluted areas.
The light pollution problem has become worse from an astronomical perspective as narrowband light sources like low pressure and high pressure sodium lamps are replaced by LED lighting. The narrowband sources had distinctive lines associated with sodium and mercury that could be filtered, but with LED lighting, this approach is not useful.
Light polluted London
london light pollution.JPG (185.57 KiB) Viewed 929 times
In the past, amateur astronomers have used deep red filters (like the Wratten #29) to push the imaging into the near infrared. More recently, some amateurs in Tokyo https://satakagi.github.io/IR-imaging-o ... pollution/ have started to use the Astronomik ProPlanet 642 BP filter, which has a very useful 200nm bandwidth of approximately 642-842nm. In this area, CMOS/CCD sensors are typically very sensitive and LED lighting has fairly little output. It also encompasses the H-alpha line.
Another advantage of imaging in this wavelength band is minimising the scattered light from the Moon. Blue light of course scatters more than near infrared and so sky glow from the Moon is much diminished.
The images below were taken with a Vixen 140 NA (140mm diameter, 800mm FL), a unique telescope that has a bit of cult following -- it is an achromat with a Petzval design, so a very flat field and quite low F ratio. It turns out, this (relatively inexpensive) telescope is very suitable for this kind of bandpass imaging. The ProPlanet 642 BP was used with an Atik 460EX monochrome camera. The mount was an HEQ5 Pro, the guide scope was a 100mm f4 Pentax lens, and the guide camera was an ASI 174MM. A red 25A filter was used on the guide scope to improve guiding performance.
M51 117 x 1 min
M51 117 x 1 min
M101 168 x 1min
M101 168 x 1min
M13 50 x 1 min
M13 50 x 1 min
I used 1 min exposures and did not have much time to take many of them since in London at the end of May, the nights are very short. Instead of Deep Sky Stacker, I tried out the ASI DeepStack that comes with ASI Studio v1.4. It's probably not as good as DSS, but it's very simple to use. Its best feature is it has a very good built in FITS viewer so you can identify and remove poor quality frames easily. In general, the ASI FitsView is very good and I think a lot people now use it as a default FITS viewer. Knowing ZWO, I'm sure their stacking software will improve quickly (I think this is their first version).
In terms of image processing, I just did a little GIMP and Photoshop Elements (nothing fancy like star masks). This was more of a proof of principle. I had previously only done planetary and solar imaging given the extreme light pollution here. Now I see deep sky is also possible.
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: Deep Sky images from a Bortles Class 9 white zone
Post by p_zetner »
These are amazing results for wideband sources from your location, Douglas!
Perhaps I’ll try my hand at some deep space imaging with this type of filter.
Thanks for posting your results.
Peter
thesmiths
Post by thesmiths »
p_zetner wrote: Fri Jun 11, 2021 8:51 pm These are amazing results for wideband sources from your location, Douglas!
Have a read of the Japanese website I mentioned. He goes through some good analysis of the spectrum of light pollution, etc. It's a really nice filter and not very expensive. I got the 1.25 inch version and put it into a filter wheel. I already have the Astronomik H-alpha and OIII so maybe will use the ProPlanet as L and try adding some colour.
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Very impressive results.
While I have a remote setup under class 2 skies to satisfy my deepsky needs, it might be fun to play with this a bit at home (class 6) as well. Will read up on that filter; thanks for sharing.
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 17925 times
Been thanked: 8891 times
Very interesting, and wonderful results too :bow hamster: I would never have imaged you could get such good images from London and in summer time too :hamster:
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Good information and great images.
Ylem
Has thanked: 99 times
Been thanked: 25 times
Post by Ylem »
Very nice captures 👍
-Jeff :movie
Solar Newbie
Coronado PST,
Lot's of other astro stuff :lol:
samrich
Post by samrich »
I'm also fond of photos, but how do you get them like this?
