WL AR2833 from 16th June
- Has thanked: 38 times
- Been thanked: 185 times
Only second imaging session in just about a year as everything has been in storage whilst moving house. Took this on the afternoon of 16th June with my CPC9.25 and Baader film. Have posted up in JPEG to respect the latest image size request so not quite as good as the original but to be honest I was surprised by how little quality is lost when converting.
Freddie
Ha: 152mm, Quark, ASI174m
WL: CPC9.25, ASI120m
- Has thanked: 8558 times
- Been thanked: 8290 times
Re: WL AR2833 from 16th June
Cracking image, Freddie. That’s a great comeback after such a long break.
- Ivan
- Has thanked: 3483 times
- Been thanked: 2262 times
- Has thanked: 20813 times
- Been thanked: 10485 times
That's great!
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Congratulations Freddie! Fantastic photo of the spot!!!
The cells are so large and clear!
Did you use some 'Barlow'?
And did you have any SSM reading of your seeing?
Alexandros
Alexandros
Alexandros
Greece
Greece
- Been thanked: 4980 times
Wow!! when I saw your name in the post, I thought 'this will be great' and I wasn't disappointed
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 9319 times
- Been thanked: 6157 times
- VasilevIvan
- Has thanked: 399 times
- Been thanked: 266 times
Great image, Freddie! Did you use any other filter in addition to Baader film?
Ivan V.
Ivan V.
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Been thanked: 4427 times
That is an outstanding image Freddie...well done
