Sunset from the city park
Moderator: Montana
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Hello everybody,
Today is a small walk in the city park around 21:00. At this time, we have +28 C °. During the day, +34 is higher than our usual temperatures at this time of the year by 10 degrees.
How I miss Ha.
Ivan
How I miss Ha.
Ivan
- 20210624_234513.jpg (1.06 MiB) Viewed 888 times
- 20210624_232439-min.jpg (627.26 KiB) Viewed 888 times
- 20210624_234343.jpg (1008.94 KiB) Viewed 888 times
- Been thanked: 4340 times
Re: Sunset from the city park
Nice sunset pics Ivan!!!
Where are you located?
- Ivan
Hi Brian,
I'm glad you enjoyed it.
This is the city of Yaroslavl, Russia.
Ivan
- Been thanked: 8793 times
These are so beautiful, thank you for allowing us to join your evening walks the first through the pine is gorgeous
Your grass is very brown, looks like it has been dry for a while. It is only 12 degrees here in the UK, the usual grey and miserable day which can happen in July or December, it is always the same but with a slight variation in between. That's why the weather causes so much chatter in the UK, when the slight variance from the norm occurs we all exclaim our surprise
- Has thanked: 8418 times
- Been thanked: 8165 times
Nice photos, Ivan.
All part of global climate change, unfortunately. I understand parts of the US are in severe drought at the moment, with record breaking high temps. As Alexandra says, we’re back under cloud/rain here in most of the UK.
- Ivan
Thanks Alexandra,Montana wrote: ↑Fri Jun 25, 2021 7:00 am These are so beautiful, thank you for allowing us to join your evening walks the first through the pine is gorgeous
I'm glad you liked it. We had an extremely hot (for our latitude 57.3 °) 8 days. And although the plants in the park are watered, the grass is still dry.
But there was a downpour at noon today. and urban plants and trees will feel better.
12 degrees is cool, of course. According to statistics, we have 80 sunny days a year, mainly in the summer months. All other days are cloudy, it rains in autumn, snow usually falls at the end of October.
Ivan
- Ivan
Thanks Stu,
I also think that this is changing the climate. Temperature records are updated annually. Our winters have become much milder, and although there is still a lot of snow, there are almost no severe frosts when the temperature drops below 20 C °.
Ivan
If you live at 57 degrees north, have you spotted the noctilucent clouds? they have been very beautiful from 20-23rd June? please post if you see them. Sadly we have too much cloud here which is disappointing.
- Ivan
Yes, I saw them in the northern and northwestern parts of the sky around 23:00 local time, an hour and a half after sunset. But, unfortunately, I didn’t take a photo. Next time I will definitely do it.
Ivan
Thanks for confirming your location Ivan...nice to have an idea where everyone is located
I hope you get some pics of the noctilucent clouds to share. I am at +44 lat, so not the best to view them, but had great views for hours on a flight across the Atlantic to Scotland in 2019. I was hoping for aurora, but got treated to these clouds instead.
- Ivan
Hi Brian,MapleRidge wrote: ↑Sat Jun 26, 2021 12:39 am Thanks for confirming your location Ivan...nice to have an idea where everyone is located
Unfortunately I have no photographs of noctilucent clouds. I've seen them quite a few times, but I've never photographed them. As soon as they appear again, I will definitely take some photos.
Ivan
