Hi all,
Today the seeing was much worst apart a few minutes in the beginning of my session (no Jetstream, excellent forecast, but ...40 degress Celcius). Therefore, I decided not to capture an animation and make some visuals and a few trials with a Bad quality old Celestron Barlow 2x.
Nevertheless, before stopping all imaging effort and while wondering around the limb, I observed a bright small feature at SE and thought to see how it will evolve through an animation of 1h. The image is very bad and the Barlow gives Newtonian rings, but I have not observed something like this before, so wanted to ask you if this is a mini flare, a special prom (much brighter than commonly), or something else.
I start with a photo of the NE proms (Lunt130MT, ASI290MM)
The same proms with the bad Celestron Barlow 2x and Newtonian rings despite the flat that I made! Although I am new to flats and may have done something wrong... With this opportunity which amplifier 2x would you propose as very good quality for solar?
And finally THE BRIGHT ERUPTIVE FEATURE that is of unknown type to me. The animation is of 63 minutes, 66 frames. We can see some material being ejected violently towards the outer space at a certain moment, and then suddenly an ejected 'fireball' accelerates a lot!
2021-6-24, Animation, Bright eruptive feature at SE, 18_05_41, B&W cropped by H- Alpha, on Flickr
All comments regarding both Amplifiers (Barlows etc.) and the unknown to me bright eruptive 'thing', are very welcome!
Alexandros
Surge Prominence at SE, Animation with bad seeing
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Alexandros
Greece
Greece
- Has thanked: 17458 times
- Been thanked: 16559 times
Re: Bright eruptive feature unknown to me at SE..., Animation with bad seeing
It looks like a surge prominence. They are often flare related. There is certainly some activity going on below it.
- Has thanked: 8355 times
- Been thanked: 8103 times
I agree with James.
- Has thanked: 17526 times
- Been thanked: 8763 times
I agree too
I find this little chart here very useful, you need to scroll down and look for Solar prominence classification https://www.prairieastronomyclub.org/ob ... n-h-alpha/
Great animation
Just out of interest you said you would be doing research at sea in August, are you a marine biologist? Pedro Re is also a marine biologist
Great animation
- Been thanked: 4908 times
This prominence is believed to from AR2835 which currently has 3-spots in a smaller region than the large AR just to the south of it.
The attached image refers.
- 25-6-2021 0915z SDO latest_4096_HMIIF.jpg (139.67 KiB) Viewed 443 times
- Has thanked: 9074 times
- Been thanked: 5977 times
Nice work Alexandros
- H-Alpha
Thank you all, James, Stuart, Alexandra, Terry, Franco.
A Surge Prominence! New to me! Thanks guys and girls. ;-)
@ Terry: This very promising! Let's see how it will evolve our new friend the AR12835.
And yes, you guessed right! I am a marine biologist like Pedro. We had exchanged a PM on this early this year.
I started by studying the ecology of benthic animals (whose life depends on the see bed), but then the 25 years together with our team we study and try to conserve whales and dolphins in Greece, the Mediterranean and globally. You might wish to have a look on some amazing short videos that we produced recently on sperm whales and other cetaceans through drone filming:
https://www.youtube.com/watch?v=nUK_6bkvHM8
https://www.youtube.com/watch?v=K3bkhu4dR3Q
Alexandros
Alexandra this chart is indeed very good and useful! Many thanks! You gave me lot of homework (for cloudy days ;-) )Montana wrote: ↑Fri Jun 25, 2021 9:23 am I find this little chart here very useful, you need to scroll down and look for Solar prominence classification https://www.prairieastronomyclub.org/ob ... n-h-alpha/
Great animation
Alexandros
Alexandros
Greece
Greece
Re: Surge Prominence at SE, Animation with bad seeing
WOW!!! what an amazing job you must be the luckiest person alive keep up the good work I am very envious but I guess a month on that little boat would be hard , I thought it would be bigger
