28.06.2021 Massive flare SW of AR12835
- Rusted
- Has thanked: 7960 times
- Been thanked: 1937 times
I captured a brilliant flare in the disturbed region just below [SW] AR12835.
It lasted about half an hour., 10-10.30[CET]
Little sign of flaring at 09.50[CET] Maximum about 10.10 [CET]
I'll have to check my video captures to be certain of the timing.
It was so bright I couldn't tame it with SharpCap. It bleached out to solid white.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
- Rusted
Re: 28.06.2021 Massive flare SW of AR12835
Some of you may be interested in the seeing conditions I had at the time of capture.
Descriptions don't usually do it justice. Here is the 10.10 CET video capture:
SharpCap was deliberately darkened to try and bring out detail in the flare. [Unsuccessfully!]
The comparison with the processed image [above] speaks volumes about the incredibly clever [free] software we have available.
SharpCap, Autostakkert [AS!3.14] ImPPG and Photofiltre7.
https://youtu.be/4cM9n2aE9OE
- Rusted
Flaring again from the same disturbed area. Seeing deteriorating.
A new spot is emerging from the limb: I saw a flare or prom, on the limb, just below it earlier.
- Has thanked: 9082 times
- Been thanked: 5977 times
Fabulous pics catching the sun in the act, Rusted. The penumbra and light bridges are very well defined in your images.
- Been thanked: 4908 times
Excellent post Chris and along with those excellent images of yours, show well that this region is very active.
Also well done on the first SolarChatter image of the newbie in the N.E. - likely to be AR2837.
Thanks for sharing
Thanks for sharing
- Has thanked: 17533 times
- Been thanked: 8765 times
- Rusted
Thank you! Praise indeed!
I'd like to thank .... in no particular order:
The seeing conditions.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Has thanked: 17464 times
- Been thanked: 16564 times
Chris,
WoW!! And I missed it. :-( . Thanks for sharing these awesome images!
- Rusted
Thanks.
It has been amazing day for better quality seeing conditions.
Morning and late afternoon were best. The bit in the middle was the usual mush.
Not quite one of those magical days. Where the solar surface is lying under shallow, crystal clear water.
Where you just have to wait for it to settle to capture it all. But still very acceptable.
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Excellent Chris!
Thanks for sharing.
I observed something similar in that area at about 17:00 pm CET.
I am not sure if I capture it. I was so disappointed by the failure of the masking experiment today and the off band slide with time during animations, that I have not fully processed the animation of today.
Hope tomorrow will regain my solar energy. ;-)
Alexandros
Thanks for sharing.
Alexandros
Alexandros
Greece
Greece
- Has thanked: 2407 times
- Been thanked: 4737 times
- Rusted
Thanks again for your encouragement.
My countless hours practising imaging and processing is finally paying off.
Thank goodness for retirement. I highly recommend it.
