I rushed the full disc mosaic a little cuz seeing was starting to go down hill. We had roadworks and trucks wizzing by so i could feel the vibrations on the ground. Im gonna have to spend more time checking the data as some of the captures are a little soft. Will try again tomorrow early when seeing will be a 5/5 rating. Im not holding my breath that it will be 5/5.
2021 06 30 HA Offerings!
- Has thanked: 1064 times
- Been thanked: 1971 times
- Ivan
- Has thanked: 3461 times
- Been thanked: 2250 times
Re: 2021 06 30 HA Offerings!
Hi Simon
These are fabulously beautiful pictures. FD is HDR? What equipment did you use?
Ivan
Ivan
All the images have a blend of HDR in them as part of the my process work flow.
This was done with the Esprit 100, Daystar Gemini and the ASI174MM
And I gots more images!! Sorry for the massive file dump everyone. I really should pitch in to the donation since im posting so much.
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Hi Simon. Your images are very beautiful!
The inverted ones become a dramatic scene.
Your FD is fantastic. I liked the colours! Your colours have always something different..., a nice surprise.
Once I had similar 'clouds' around the sun and in my case these were probably artifacts. Yes or not, it does not matter because in your case they add a lot of ambience in the photo!
best wishes,
alexandros
best wishes,
alexandros
Alexandros
Greece
Greece
- Has thanked: 17521 times
- Been thanked: 8763 times
The full disc is quite magnificent, great eye candy too what a fabulous set
- Has thanked: 2406 times
- Been thanked: 4737 times
- Been thanked: 4908 times
Well done Simon on producing such excellent images and the presentation.
Thanks vm
Thanks vm
