Imaging AR12835 in 540nm light. 7-1-21
- Has thanked: 17458 times
- Been thanked: 16550 times
Session time is from 13:50 to 16:00 UTC. Very intermittent sun under mostly cloudy skies. Rain sent me in around noon local time. The seeing is below average and the temperature is 82F. ( 27.8 C ) I never had a chance to observe visually or image in Ha. I only have three 540nm filtered continuum images. They were done using the ZWOASI178MM monochrome camera on my Celestron NexStar 102 GT refractor using the Altair solar wedge. Image acquisition was done using ZWO's ASIStudio and editing using GIMP.
Carpe Lumen!
And one by the SDO HMI continuum instrument.
Carpe Lumen!
- Petrus
- Has thanked: 1495 times
- Been thanked: 683 times
Re: Imaging AR12835 in 540nm light. 7-1-21
Great images! The sunspot looks fantastic. Thank you for sharing, James!
~ Petrus ~
Flickr
Flickr
- Has thanked: 2406 times
- Been thanked: 4737 times
- Been thanked: 4908 times
Thank you James for sharing your own captures which are quite excellent.
I must admit, I haven't even tried the ASI Studio yet, so perhaps tomorrow I will try that prog out and if no Sun, will try some older RAW files.
I don't see anyone here using the ASI Studio software. It seems straightforward and user-friendly. Today was the first time I have tried it.
A little while later I used the Lunt 8x32 SUNoculars. The large sunspot of AR12835 is sizable even at that low of a magnification. It should be visible unaided with a filter. I could also see a few of the smaller spots trailing it!
- Been thanked: 4299 times
Great details captured in AR2835/2836 James...nice work
I have mixed impression of ASI Studio, though of all its offerings I have used it for some deep sky imaging using the cooled ASI294MC camera. I guess I have use other software for so long that I I have yet to feel comfortable with it.
Terry, the ASI software is for image acquisition not processing.
Brian,
Same here. I have gotten used to SharpCap.
Thanks Brian but they just don't quite show enough detail. Seeing wasn't that great today either.
- Has thanked: 17521 times
- Been thanked: 8763 times
Don't knock them James, at that scale that is about the level of detail you will see. I think they are great
- Has thanked: 9074 times
- Been thanked: 5977 times
Very, very good images, James, great resolution and detail. White light is very satisfying, specially when the sunspots are large and complex.
- Martin_S
- Has thanked: 975 times
- Been thanked: 2987 times
Nice imaging James, well done. Like Brian I have tried ASI Studio on Deep Sky and I have found it lacks a lot of features. I must admit it's very easy to use. My main capture software for Deep sky is Sharpcap and for Solar and Lunar I use Firecapture.
Martin
Martin
H alpha : ,Skywatcher 100mm F10 open frame refractor, a tilted 2" 7nm H-alpha filter as a sub energy rejection filter, Baader TZ4 telecentric focal extender, Player One energy rejection filter, Combo Quark Chromosphere, Naked PST etalon for double stacking, ASI74mm camera
- Has thanked: 6161 times
- Been thanked: 7096 times
