Today, 5th July, marks the Aphelion, the day of the year when the sun is farthest from Earth. This image shows a comparison of the size between the sun in Perihelion (when Sun is closest to Earth) and Aphelion. Although the difference in their sizes is not as apparent as that of Moon in Perigee and Apogee, the Sun in Perihelion is 3% larger in the sky than the Sun in Aphelion (1 arcminute larger).
Both the images were taken with the same equipment at same focal length (600mm) from the same location (Kolkata, India).
Gear: Nikon D5600, Sigma 150-600c, Thousand Oaks Solar Filter (white-light)
Software: PIPP, Adobe Camera Raw, Photoshop
Date: 2nd January 2021 and 5th July 2021
Battle of the Sun(s)
- Has thanked: 171 times
- Been thanked: 252 times
- PSX_20210705_104840.jpg (677.74 KiB) Viewed 459 times
Last edited by SoumyadeepMukherjee on Mon Jul 05, 2021 5:57 am, edited 1 time in total.
- Has thanked: 17458 times
- Been thanked: 16551 times
Re: Battle of the Sun(s)
That should amount to 1 arc minute difference. Not 1 arc second.
That's neat that you were able to gauge the sun's size between perihelion and aphelion. I have wondered how I would do that myself.
Thank you for pointing it out. I have updated the description.DeepSolar64 wrote: ↑Mon Jul 05, 2021 5:46 am That should amount to 1 arc minute difference. Not 1 arc second.
- Has thanked: 17521 times
- Been thanked: 8763 times
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
You are doing an excellent work!
Thanks a lot for sharing this. It is very beautiful, useful and educative!
Do you know when the next Perihelion is, just in case you have searched for it already? (the exact day)
Alexandros
Alexandros
Alexandros
Greece
Greece
