TMB 175 F/8
Moderator: Montana
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: TMB 175 F/8
WoW, Pedro! I am thoroughly impressed. Professional grade work you do on all accounts. If you wrote a book on imaging I am sure it would sell.
Two thumbs up!!
Two thumbs up!!
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Re: TMB 175 F/8
Thanks James
A worote a book in 2002 (in Portuguese)
http://www.astrosurf.com/re/index_ceu.html
RÉ, P. (2002). Fotografar o céu. Plátano Edições Técnicas, 303 pp. ISBN-972-707-345-X
- capa_final.jpg (132.43 KiB) Viewed 3060 times
Pedro Re'
Re: TMB 175 F/8
I bet it's very informative too!
- pedro
Re: TMB 175 F/8
Yes James but it is a bit outdated...
Pedro Re'
- pedro
Re: TMB 175 F/8
TMB175 STL11000 flat screen Gerd Neumann
- TMB175_STL11000_FLAT_20220114_MOSAIC.JPG (966.62 KiB) Viewed 3029 times
Pedro Re'
Re: TMB 175 F/8
Pedro,
That will probably prove useful to you. DayStar makes a flat screen too.
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220121)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (M35/M38)
http://pedroreastrophotography.com/
M035. 155min (31x5min). TMB175 F/8, FF, STL11000, Median, DDP, Paramount ME
M038. 30min (6x5min). TMB175 F/8, FF, STL11000, Median, DDP, Paramount ME
Pedro Re'
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220122)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (M36/M38)
M036. 100min (20x5min). TMB175 F/8, FF, STL11000, Median, DDP, Paramount ME
M038. 180min (36x5min). TMB175 F/8, FF, STL11000, Median, DDP, Paramount ME
Pedro Re'
Re: TMB 175 F/8
WoW, Pedro. You are an accomplished astrophotographer not only in solar but in deep-sky as well.
- pedro
Re: TMB 175 F/8
Thanks James
Check out a GEOPTIK Flat Field Generator I received today
GEOPTIK_FLAT_FIELD_GENERATOR_20220124_MOSAIC by Pedro Re', on Flickr
Pedro Re'
Re: TMB 175 F/8
WoW Pedro! This one is powered, not like the flat field cap that DayStar sells. It must be adjustable in some way?
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Re: TMB 175 F/8
Agreed!!!
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220125)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (M37/M81)
M081. 150min (15x10min). TMB175 F/8, STL11000M, Median, DDP, Paramount ME.
M037. 100min (20x5min). TMB175 F/8, FF, STL11000, Median, DDP, Paramount ME
Pedro Re'
- Ivan
Re: TMB 175 F/8
Pedro, this is very beautiful. I also shot the M81 with a short refractor and it was a failure. I had a three hour total exposure, but the arms of the galaxy barely showed up, and the stars were swollen due to poor vision. Your work is simply magnificent, what is the final exposure?
Ivan
Ivan
- pedro
Re: TMB 175 F/8
Thanks Ivan
here is another mosaic (M81) - SCREEN MASK INVERT
Pedro Re'
Re: TMB 175 F/8
Professional quality work Pedro! The only deep sky astrophoto I have ever done was of M31 using my iPhone. I got the bright central region ok but it didn't pick up the fainter outer regions of the galaxy.
Can the ZWO ASI178MM be used for deep sky astrophotography?
- Ivan
- Ivan
Re: TMB 175 F/8
James, I think compact objects like planetary nebulae are fine. Of course, the result will not be as impressive, but something will work out. It is necessary to understand with which telescope it is better to use it. Previously, I used Stellarium, where it is possible to see how this or that object will fit (or not) on the matrix of your camera.DeepSolar64 wrote: ↑Thu Jan 27, 2022 3:40 pm Professional quality work Pedro! The only deep sky astrophoto I have ever done was of M31 using my iPhone. I got the bright central region ok but it didn't pick up the fainter outer regions of the galaxy.
Ivan
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220128)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (M35/M81)
M081. 330min (33x10min). TMB175 F/8, STL11000M, Median, DDP, Paramount ME.
Pedro Re'
- pedro
Re: TMB 175 F/8
Thanks James
ZWO cameras are great for deep-sky imaging but you have to use the cooled version. You can try using your uncooled AS178MM for bright objsects (e.g.clusters)
Pedro Re'
Re: TMB 175 F/8
pedro wrote: ↑Sat Jan 29, 2022 2:16 pm Thanks James
Globulars maybe? Bright ones like M13, M5 or M22?
- pedro
Re: TMB 175 F/8
Yes, try short integrations (1 to 5min) and combine the images
DeepSolar64 wrote: ↑Sat Jan 29, 2022 2:19 pmpedro wrote: ↑Sat Jan 29, 2022 2:16 pm Thanks James
Pedro Re'
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220201)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (M34/M81)
Pedro Re'
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' | CCDInspector
Pedro Re'
- pedro
Re: TMB 175 F/8
DIGITAL IMAGE PROCESSING TUTORIALS | Pedro RE'
DEEP-SKY IMAGING | MaxImDL, Photoshop CS6 & PixInsight
TMB175 F/8 | SBIG STL11000 (M81)
- M081_TMB175_STL11000_15X5Min_Median_20220125_DDP_PIXINSIGHT_MOSAIC_NEW.jpg (3.37 MiB) Viewed 2744 times
Pedro Re'
- pedro
Re: TMB 175 F/8
PixInsight Image Annotation (M51, M81/82, M101)
DEEP-SKY IMAGING | PixInsight (EZ Processing Suite)
DEEP-SKY IMAGING | TMB175 F/8 | SBIG STL11000 (M81)
PixInsight (Image registration/Image integration)
Pedro Re'
- pedro
Re: TMB 175 F/8
DEEP-SKY IMAGING | TMB175 F/8 | SBIG STL11000 (M42)
PixInsight (HDR Multiscale Transform)
Pedro Re'
- Been thanked: 10248 times
Re: TMB 175 F/8
You get great results with this setup Pedro!
- pedro
Re: TMB 175 F/8
Thanks Mark
PixInsight is great but it does have a steep learning curve
Pedro Re'
- pedro
Re: TMB 175 F/8
PixInsight (Auto_Background_Extractor/Dynamic_Background_Extractor
Pedro Re'
- pedro
Re: TMB 175 F/8
PixInsight (Screen Transfer Function | Histogram Transformation)
Pedro Re'
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220430)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (Abell 1185)
- CCDINSPECTOR_TMB175_STL11000_5_20220430.jpg (331.17 KiB) Viewed 2544 times
- N3561_TMB175_STL11000_5_33X10Min_Median_20220430_DDP_PROC_neg.jpg (1.37 MiB) Viewed 2544 times
- N3561_TMB175_STL11000_5_33X10Min_Median_20220430_DDP_MOSAIC.jpg (1.81 MiB) Viewed 2544 times
Pedro Re'
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220508)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (SN2022hrs, M51)
Pedro Re'
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (2021/2022)
Paramount ME (TEC140 F/7 APOGEE Alta 8300 | TMB175 F/8 SBIG STL11000)
Pedro Re'
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220625)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (M106 | M013)
M106_TMB175_STL11000_12X10Min_Median_20220625_DDP_CROP_PROC_MOSAIC by Pedro Re', on Flickr
M013_TMB175_STL11000_12X5Min_Median_20220625_DDP_MOSAIC by Pedro Re', on Flickr
Pedro Re'
Re: TMB 175 F/8
I never tire of seeing M13. I’ll never forget seeing it for the first time in my old 50mm Focal refractor at 50x for the first time just over 40 years ago. Even though it appeared in the scope as a fairly faint fuzzy ball. It ignited my interest in deep sky and boosted my interest in astronomy at that time. ( March 1982 ) I’d had the scope since December 1978 but had used it only to view the Moon, Sun, Venus, Mars, Jupiter and Saturn. It and a pair of 10x50 Traq binoculars served me well at the time for Deep Sky. But spurred on by M13 I would purchase a better 60mm Traq refractor and a Coulter 10.1” Dobsonian by mid 83’. The dob blew me away since it resolved the cluster into a bright ball of stars and brought so much more into view. I still have the 60mm Traq and Coulter 10.1” Odyssey Compact. I just wish I still had the time to observe that I did in those days.
JP
JP
- pedro
Re: TMB 175 F/8
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (M051)
M051_TMB175_STL11000_14X10Min_20220626_DDP_PROC_Annotated by Pedro Re', on Flickr
M051_TMB175_STL11000_30X10Min_20220626_DDP_MOSAIC by Pedro Re', on Flickr
remote_20220626-06 by Pedro Re', on Flickr
Pedro Re'
Re: TMB 175 F/8
You seem to have nice dark skies, Pedro.
Do you use a DSLR or a videocam and image stacking to take these?
- pedro
Re: TMB 175 F/8
No James, I always use refrigerated CCD cameras STL11000 (Full Frame)
Pedro Re'
Re: TMB 175 F/8
WoW, neither a videocam or a DSLR. I guess you can stack with these, Manually I guess. Or are there a need to?
http://pedroreastrophotography.com/STL1 ... .12.11.pdf
- pedro
Re: TMB 175 F/8
Pedro Re'
- pedro
Re: TMB 175 F/8
I use several programs to align and stack the deep-sky images - MaximDL & PixInsightDeepSolar64 wrote: ↑Mon Jun 27, 2022 5:25 pm WoW, neither a videocam or a DSLR. I guess you can stack with these, Manually I guess. Or are there a need to?
Pedro Re'
- pedro
Re: TMB 175 F/8
DEEP-SKY IMAGING | TMB175 F/8 | SBIG STL11000 (M13)
PixInsight (HDR Multiscale Transform) | PS CS6
Pedro Re'
Re: TMB 175 F/8
I’ll take a look Pedro. I am certainly curious on how you get these wonderful deep sky pictures.
- pedro
Re: TMB 175 F/8
PixInsight | http://pedroreastrophotography.com/
- M013_TMB175_STL11000_12X5Min_Median_20220625_DDP_HDR_MOSAIC_PIX.jpg (3.99 MiB) Viewed 2245 times
Pedro Re'
Re: TMB 175 F/8
Very nice work Pedro!
- pedro
Re: TMB 175 F/8
Roll-off-roof Observatory | Pedro RE' (20220701)
TMB175 F/8 | SBIG STL11000 | PARAMOUNT ME (SN2022hrs, M051)
Pedro Re'
- pedro
- pedro
Re: TMB 175 F/8
DEEP-SKY IMAGING | TMB175 F/8 | SBIG STL11000 (M51)
- M051_TMB175_STL11000_40X10Min_Median_20220701_DDP_DBE_MOSAIC.jpg (3.03 MiB) Viewed 2204 times
- M051_TMB175_STL11000_40X10Min_Median_20220701_DDP_DBE_PROC_NEG.jpg (2.85 MiB) Viewed 2204 times
- M051_TMB175_STL11000_40X10Min_Median_20220701_DDP_DBE_PROC.jpg (971.97 KiB) Viewed 2204 times
Pedro Re'
