Hi folks,
just wanted to show my idea of a PST40 mod 1 focuser.
Just a NEMA14 stepper controlled by Bob Browns MyfocuserPro2. Printed with PLA.
Works pretty nice and smooth.
Next steps:
- add a motor for the etalon adjustment
- add a second pcb for the second motor
- print a GT2 belt of TPU (to replace the rubber ring of the etalon for the GT2 belt)
Updates are coming soon.
PST40 motor focuser
- Bastelhannes
- Has thanked: 83 times
- Been thanked: 138 times
- Bastelhannes
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: PST40 motor focuser
Cool mod!
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Neat job. Well done!
The PST's textured rubber ring provides plenty of grip for a GT2 belt.
[I used a "Skywatcher" DC focuser motor.]
However, it doesn't offer repeatable indexing for a stepper motor drive.
- Bastelhannes
Thank you.
I was thinking about using the original rubber ring of the etalon. But hey, I have a printer here, so why not using it? Hopefully I am going to have it built until Monday.
The only disadvantage so far: the pentaprism shifts while focusing. I am going to tear the black box open again. Last time i adjusted the pentaprism, because it had have an angle of about 15. It was not possible to rotate it over the edge so it would come into the desired position. I just cut it off and heated it together again (I was lacking of silicone glue).
Not good for flat frame making...
- Been thanked: 4434 times
Great addition to the scope...well done !!!
- Bastelhannes
And... modified it:
- two motors (unfortunately two PCB myFocuser2Pro are necessary, attached to each side)
- used now high impact PLA (the green body) and carbon fibre PETG (the motor holders)
- for the moment I used TPU for the teeht ring (Etalon) and the belt itself...
Now waiting for the sun...
- IMG_5878.JPG (2.44 MiB) Viewed 2153 times
- Bastelhannes
By the way, if anyone needs the .stl or Fusioon360 files.. just drop a message. I am glad to share...
