Well after waiting 2-months for the delivery of the new SkyWatcher "Esprit" 80ED Apo-Triplet scope (to replace the Orion ED80T-CF with its' snags) and then waiting a further week or more, to align it with the Lunt 60 Ha and Cal-K scope as the Tri-scope Assembly on the SkyWatcher AZ-EQ6 mount, at least early today the sky was clear and although quite windy, was the time for completing the installation.
A further post with some close-up images of the newbie, will happen shortly, as one or two interesting innovations that are making this acquisition superior to the scope it has replaced.
As the alignment was completed quickly, before the clouds really started to interfere, the attached captures show that today, the prominences are the main-feature for imaging. Not a lot else was really visible with the seeing which was a little turbulent...
Further work is in progress to take and produce better images from the Tri-scope Assembly, but limited time today, where other things need doing...
Thanks for looking
1st Light - SkyWatcher 'ESPRIT' 80ED for White-Light
- Been thanked: 4908 times
- 7-2021 SkyWatcher 'Esprit' 80ED.jpg (727.72 KiB) Viewed 338 times
- 29-7-2021 0815Z ESPRIT - 1st light.jpg (261.5 KiB) Viewed 338 times
- 29-7-2021 0816z CaK.jpg (853.05 KiB) Viewed 338 times
- 29-7-2021 0817-2 Ha-Proms.jpg (222.37 KiB) Viewed 338 times
- 29-7-2021 0817z Ha-SS.jpg (862.79 KiB) Viewed 338 times
- Has thanked: 17523 times
- Been thanked: 8763 times
Re: 1st Light - SkyWatcher 'ESPRIT' 80ED for White-Light
Terrific images Terry I love the prom shot you only just managed to fit that monster on
- Has thanked: 17458 times
- Been thanked: 16559 times
Congratulations Terry!! Your first light was a success!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Well done Terry, with the first light and the SPoD of the day accolade.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Many thanks Ella and as per email-reply.
Regards
Regards
