In capturing solar images with Sharp Cap, I occasionally generate SER videos in which I see a small number of wobbly frames in the midst of an otherwise good capture. Other then setting limits at either end of a video, can Autostakker be used to delete bad frames elsewhere in the video? Kind of like introducing a deletion mutation in DNA.
Jordan
How Remove Bad Ser Frames
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Re: How Remove Bad Ser Frames
Jordan, I believe that SER player can edit rogue frames from your captures.
Martin
Martin
- nicspenceryork
- Has thanked: 6113 times
- Been thanked: 1348 times
Hi Jordan, with the unwanted frame in view in Autostakkert you hit the space bar, the frame information turns red and then AS ignores it.Jordan Konisky wrote: ↑Wed Aug 04, 2021 12:03 am In capturing solar images with Sharp Cap, I occasionally generate SER videos in which I see a small number of wobbly frames in the midst of an otherwise good capture. Other then setting limits at either end of a video, can Autostakker be used to delete bad frames elsewhere in the video? Kind of like introducing a deletion mutation in DNA.
Jordan
- Jordan Konisky
Thank you Martin and Nic, Exactly what I was looking for.
Jordan
Jordan
Jordan -
