Terrible seeing, but good enough to get a nice full disc. Intermittent clouds in the a.m. as well, so happy to come away with anything:)
Lunt100 single stack with asi294mm+ROI, single capture with stretching in post processing to bring out the prominences.
Full disc h-alpha, 10th of August
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Full disc h-alpha, 10th of August
Great you got something, something is better than nothing. Well done and thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17521 times
- Been thanked: 8763 times
