Spots and Flare in CaK with a T300
- Has thanked: 695 times
- Been thanked: 496 times
Still in St Veran.
I'm switching now to a CaK setup, with the non coated T300.
While imaging 2 small spots, then came a flare.
I needed to set down the shutter settings capture after capture.
The flare itself developed up and down during ~2 minutes.
CS
Alex
2021-08-16
Solar Newton T300
Baader FFC
Lunt CaK Mod
ASI290MM
Still in St Veran.
CS
Alex
2021-08-16
Solar Newton T300
Baader FFC
Lunt CaK Mod
ASI290MM
- Has thanked: 6161 times
- Been thanked: 7097 times
Re: Spots and Flare in CaK with a T300
Very impressive set, Alex! The short animation is very nice!
Arne
Arne
- Has thanked: 8355 times
- Been thanked: 8103 times
Fantastic, Alex. Impressive flare animation.
- Has thanked: 17458 times
- Been thanked: 16562 times
Impressive! Yes. And these spots are actually quite small.
- sulcis2000
- Has thanked: 2 times
- Been thanked: 477 times
Only one word! OMG!!
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- Has thanked: 17533 times
- Been thanked: 8763 times
OH MY Goodness!!! a CaK flare in animation too!! these are so good
I always imagined these events happened on the surface but when you watch this closely in a large version view, it looks like this is above the two spots and connecting like lightning in the surrounding space above. I have never seen this at such high resolution before and is highly intriguing.
- Has thanked: 9082 times
- Been thanked: 5977 times
- Been thanked: 4885 times
Alex:
Super shots, the flare looks like a lightning bolt in the animation.
- Has thanked: 42 times
- Been thanked: 1485 times
Do you find the solar Newtonian has fewer aberrations at 400nm than a typical refractor? I have a smaller one (130mm) and I had assumed it would be sharper than my 106mm APO refractor. But I could not really tell since I was limited by seeing rather than optical aberrations. In the few comparisons I made, the refractor was actually better.
- Been thanked: 4302 times
Hi Alex...
Superb animation and details in the images. Incredible results
