We decided to get a new diffraction grating for our "foam board" spectroheliograph. The new one is a 30mmx30mm 2400 l/mm holographic grating from Edmund Optics. The old one (which we had had around for many years) was a 50mmx50mm 1800 l/mm ruled grating from Thorlabs. The new grating, because of the increased dispersion, should give increased contrast of surface features (and it does seem to deliver on the promise). Here is a composite of two images, East and West, taken with two scans. Our SHG software is able to generate the protuberance images simultaneously and we could assemble this mosaic fairly effortlessly.
The average FPS was 432 and the ROI was 2000x120. The exposure was 2.1 ms and the scan was 16x sidereal rate (approximately 8 seconds per scan). The camera was a ZWO 178MM at a gain of 190.
The SHG image compares favourably with a full disk image using an etalon: viewtopic.php?f=4&t=33121 taken on the same day.
Next improvement needs to be the slit, which is too short (only 3mm long, hence not being able to cover the full disk even with two scans). Our old 10 micron wide Thorlabs slit has also suffered wear and tear over the years which results in the vertical lines (and that is difficult for the automated software to entirely remove).
Improved SHG H-alpha imaging at 700mm FL
- Has thanked: 42 times
- Been thanked: 1485 times
- Has thanked: 17521 times
- Been thanked: 8763 times
Re: Improved SHG H-alpha imaging at 700mm FL
WOW!! absolutely magnificent! they just get better and better
- Has thanked: 20229 times
- Been thanked: 10111 times
Very good indeed, really impressive results!
- Has thanked: 17458 times
- Been thanked: 16549 times
It certainly has nice contrast!!
