The forecast was correct and the Sun was out this morning, hanging in a beautiful blue sky....perfect....except that the seeing conditions were pretty poor to say the least. I managed a Ha and Ca II K FD, but absolutely could do nothing in WL. Granulation was poorly visible and the main active region was unstable on screen and I was barely able to focus.
I did manage a couple of shots on the 150mm mod earlier on, but even then the images were not the best. Anyhow it's a record of how the Sun looked this morning from the UK.
20210920_CaK_FD_Mono by Stuart Green, on Flickr
20210920_CaK_FD_colour by Stuart Green, on Flickr
Triple stacked Lunt 60 with 'Bob's mod:
20210920_Ha_FD_Mono by Stuart Green, on Flickr
20210920_Ha_FD_colour by Stuart Green, on Flickr
...and the closer views on the 150.
AR12871
20210920_Ha_AR12871_Prom by Stuart Green, on Flickr
Long Filament
20210920_Ha_Filament by Stuart Green, on Flickr
Thanks for looking.
Monday Sun 20th September 2021
- Has thanked: 8352 times
- Been thanked: 8103 times
- Has thanked: 6161 times
- Been thanked: 7096 times
- Has thanked: 3292 times
- Been thanked: 1879 times
Re: Monday Sun 20th September 2021
Clear spells here as well.
I observed over the house earlier than normal and saw the 3 main proms plus lots of smaller ones. In the 90mm and Quark 4.2x Chromo with 25mm Clave'.
The small ones dissapeared once things warmed up.
Also I could see the surface details in the Mak180 PST mod with the bino-viewers up to 150x, just like the image.
Cheers. Andrew.
Cheers. Andrew.
- marios i.
- Has thanked: 1709 times
- Been thanked: 1125 times
Beautiful images Stu
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 17521 times
- Been thanked: 8763 times
Stunning view Stuart, the CaK image is a real cracker. With CaK we can see 4 maybe 5 regions where there will be new ARs forming in the next few days or weeks. Bright intense formations in plage in CaK are a real give away. We can also see a long since decayed region too. CaK is a very revealing snapshot into the birth and death of active regions.
PS I notice this post has a duplicate so I deleted it
- Been thanked: 4299 times
These are excellent images Stuart...excellent work
