Good morning everyone. I am Attila Dézsi from Hungary. I only registered for the forum yesterday, but I have been reading it for months. I would like to introduce the conversion of the telescope and say thank you at the same time. Because I got a lot of ideas and help from this group. The telescope is a blue tube SkyWatcher 120/1000. Internal 90mm Baader D-ERF. I made a 2 "adapter for the Lunt etalon so it can be inserted into any 2" focuser. I later cut the tube shorter so I have focus with a binocular viewer and 20mm eyepieces. This is how I use it most often. Photographically, I use an ASI290mm camera. I am very pleased with the result. Whenever I have free time, I use it. So thank you again
Here are some photos
120/1000 Lunt LS50 mod
- AtiCelestron
- The Sun?
- Been thanked: 7 times
- 1630410942.jpg (691.49 KiB) Viewed 2535 times
- 1632049628 (1).png (2.54 MiB) Viewed 2535 times
- 20210902_140904 (1).gif (3.91 MiB) Viewed 2536 times
- H-2.jpg (1.03 MiB) Viewed 2536 times
- Sun_Halpha_165448_100921_lapl4_ap1220_conv (1).jpg (615.17 KiB) Viewed 2536 times
- éztet (1).jpg (99.99 KiB) Viewed 2536 times
- 20210902_103617 (1).jpg (2.16 MiB) Viewed 2536 times
- AtiCelestron
- The Sun?
Re: 120/1000 Lunt LS50 mod
Thank You GUS.
My main instrument is an old C8 that I use for Moon observation and with Baader solar foil to observe Sunspots. The mount is a HEQ5 pro goto. I tilted the internal ERF 2 degrees, one of the pictures shows the reflected light on the front lens. I designed a heating module for the block filter, the power of which can be controlled from an energy distribution box. I will be testing the heating module now in the winter. There are also plans to make a scintillation monitor.
- received_184006130158468.jpeg (86.73 KiB) Viewed 2527 times
- received_317508202950688 (1).jpeg (27.76 KiB) Viewed 2527 times
- 20210715_160452.jpg (1.7 MiB) Viewed 2527 times
- 20210715_160310.jpg (1.63 MiB) Viewed 2527 times
- received_795216404511006.jpeg (95.29 KiB) Viewed 2527 times
- 20210928_083358.jpg (589.1 KiB) Viewed 2527 times
- PSX_20210306_145351.jpg (5.42 MiB) Viewed 2527 times
- Has thanked: 20813 times
- Been thanked: 10487 times
Welcome to the forum! That's a pretty neat mod you've got there!
- AtiCelestron
- The Sun?
I was afraid of work. I have no knowledge of optical things. especially not with h-alpha. but I am very pleased with the end result. I just don't like the "sweet-spot". when viewed with binoculars, I see the full disk, but the size of the sweet spot is smaller than the full disk. so I have to move the image of the Sun in the field of view to see the eruptions on the edge. photographically I use an ASI290MM. it is out of frequency in 1/4 of its field of view. probably the wide sensor sticks out of the sweetspot
helloAtiCelestron wrote: ↑Tue Sep 28, 2021 6:57 amThank You GUS.
i have some question,
what is lunt 50mm etalon thread mm?
mean i want remove focuser like you,
my telescope backfocus is 150mm, so I want to make a shorter optical path.
so want make adopter but i dont know information, so please.
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
I'm assuming you mean the whole etalon assembly. Objective side: M68x1, focuser side: M35x0.5.
- Has thanked: 1188 times
- Been thanked: 1382 times
Great mod Attila! That worked out quite well. Nice that it didn't require any major reconstruction too!
