... timelapse
Yesterday I tried to make a timelapse of a Sun set and honestly I do not know if I succeeded. Perhaps the chosen focal length was not good
I will try today again.
https://rainerehlert.com/00_SCHForum/Su ... 05_500.mp4
and at night, I do not know if this belongs here at all, I was able to get 3 lightning strikes
Sun set ...
Moderator: Montana
- Has thanked: 9414 times
- Been thanked: 5578 times
- Been thanked: 4340 times
Re: Sun set ...
These lightning photos are great to see Rainer...well done !!!
The sunset animation looks great too. Where was this taken...appears to overlooking the ocean at a resort?
Re: Sun set ...
Hi Brian,MapleRidge wrote: ↑Thu Oct 07, 2021 1:23 am These lightning photos are great to see Rainer...well done !!!
Thanks and yes it is from a Hotel at the Pacific coast near Puerto Vallarta in Mexico.
Here is the Sunset time lapse of today at 200 mm focal length.
https://rainerehlert.com/00_SCHForum/Su ... 06_400.mp4
- Been thanked: 8792 times
Re: Sun set ...
These really made my morning thanks Rainer
I loved both scales for individual reasons. It was funny watching all the people in the pool
The lightning is amazing too!
You should pop the two timelapses in the October solar challenge!
Re: Sun set ...
A fabulous set of captures Rainer and the cloud animation shows so well how clouds can operate at the high-levels too.
Thanks for sharing
- JochenM
- Been thanked: 1619 times
Re: Sun set ...
Very nice, Rainer.
Did you use a trigger for the lightning shots or just try to time it correctly with lightning-fast reactions?
Re: Sun set ...
Hi Jochen,
It is quite simple. Take a self timer and set it in that way that you take continuously images.
I used the Canon Zoom lens EF 11-24 at f/4.0 set at 24 mm and exposed for 60 seconds in bulb mode. Let it just run and you will get a lot of Lightning strikes.
Before choosing an exposure time make a few test shots and see what happens with overexposure of the surroundings when no lightning is there.
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Re: Sun set ...
Very, very beautiful photos and videos. Freezing lightning was my old dream - it's gorgeous footage!
Watching the sunset, could you see the "green flash" at the very end?
Ivan
Ivan
Re: Sun set ...
Hi Ivan,
Thanks and no, no green flash. There where also clouds reaching farther away then the Horizon and so the Sun did not set over the Sea horizon which is the moment the green flash appears.
Today i tried it again, but again clouds reaching farther away from the Horizon.
- Has thanked: 9145 times
- Been thanked: 6025 times
