10 Oct 2021, AR12882 and WL Animation
An archive of all the best images Solar Chat has to offer!
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Kalimera all!
Against Jetstream and weather forecast, in between heavy clouds and a storm we had 3 hours of a beautiful sunny day with a fair seeing that allowed me to have some sun imaging after quite some time and my best WL granulation so far. The session included WL and H-Alpha.
Although I was experimenting with the Barlow in WL and had not planed (unfortunately) an animation in WL, I tried a posteriori to make one with 25 frames of successive captures that lasted 16 minutes. Despite one gap and some flickering (since the image processing had to be made manually...), I could record for the first time during my sun-life the boiling WL granules! :-) :-) :-)
Therefore, I thought worthy to share. ;-)
The WL of AR1212882 today
2021-10-10, AR12882 in WL, 12_57_52 UTC Colour.jpg (1.63 MiB) Viewed 488 times
Image2021-10-10, AR12882 in WL, 12_57_52 UTC by H- Alpha, on Flickr
Image2021-10-10, AR12882 in WL, 12_58_57 UTC by H- Alpha, on Flickr
The WL Animation
Image2021-10-10, Animation of AR12882 in WL, 16 min, 25 frames, 13_05_16 UTC by H- Alpha, on Flickr
The complexity and variety of proms in the NW limb
Image2021-10-10, AR12882 and NW limb in H-alpha, 13_53_23 UTC by H- Alpha, on Flickr
AR12882 in H-alpha
Image2021-10-10, AR12882 in H-alpha, 13_34_35 UTC by H- Alpha, on Flickr
Image2021-10-10, AR12882 in H-alpha, 14_12_07 UTC by H- Alpha, on Flickr
Alexandros
Alexandros
Greece
Has thanked: 17458 times
Been thanked: 16550 times
Re: 10 Oct 2021, AR12882 and WL Animation
Post by DeepSolar64 »
These are all beautiful, Alexandros! The boiling photosphere around the spots of AR12882 is well shown. Though I find your Ha images outstanding it's the continuum images I am just blown away by. Only fair seeing and they show the granulation cells and fine sunspot details so easily.
What scope did you use on the white light images?
Two thumbs up!!
H-Alpha
Post by H-Alpha »
Thanks a lot James!
Sorry I forgot to add the scope.
All was with Lunt 130MT + ZEISS Abbe Barlow
+ Baader Solar Prism for WL
The Barlow was at 1.7x for the photos and at 3x for the animation.
I wrote "fair seeing" because the SSM indicated an average of 1.7.
2021-10-10, SSM data.jpg (207.15 KiB) Viewed 465 times
However, I believe that the seeing was the best I ever had. I have posted SSM data in the past with average close to 1.0 and minimum at 0.3 or 0.4 that did not give as good results as these. So, SSM is an indication, but as people with much more experience have commented, it does not represent well some atmospheric layers.
PS: I also love the WL ;-)
Alexandros
Alexandros
Greece
Has thanked: 9074 times
Been thanked: 5977 times
Post by ffellah »
Alexandros: excellent results and I love your white light animation. I have not seen many of these in the forum.
MAURITS
Has thanked: 2406 times
Been thanked: 4737 times
Post by MAURITS »
Great session Alexandros, the WL Images are excellent.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
The Lunt 130MT shows the granulation suberbly!
Has thanked: 8352 times
Been thanked: 8103 times
Post by Carbon60 »
Superb WL images and animation, Alexandros. Very nicely done.
Stu
GreatAttractor
Has thanked: 747 times
Been thanked: 753 times
Post by GreatAttractor »
Excellent results. I'm thinking more and more of getting an intermediate 5"-class setup.
As for the animation, note also how the inner tips of the penumbral filaments seem to move inward (though the material in them moves outward - it's known as Evershed flow). You'll see it better once you capture a longer one, like below (1.5 h):
My software:
My images
arnedanielsen
Has thanked: 6161 times
Been thanked: 7096 times
Post by arnedanielsen »
Excellent images Alexandros. I particularly like the WL images and the animation is just stunning!
Thanks for sharing,
Arne
Arne
Has thanked: 17521 times
Been thanked: 8763 times
Oh my goodness!!! well done :bow :bow :bow
Has thanked: 64 times
Been thanked: 4299 times
Post by MapleRidge »
Truly magnificent images and animation Alexandros :bow
