26th Oct. A prominence erupted today on the Sun's NE limb just before midday in SE Australia (12-40 am UT) - it lasted for only about 15 minutes. I managed to image the eruption - conditions were not the best but it was spectacular. I had to overexpose the surface in order for the eruption to show up. Lunt 100 Ha scope with Canon 550d camera. Single exposures of 1/80 sec.
The last image shows the Sun's southern hemisphere with some sunspots and flares (ARs are numbered).
Thanks for viewing.
26th Oct - Prominence eruption
- Been thanked: 1551 times
- Has thanked: 17526 times
- Been thanked: 8763 times
- Has thanked: 2407 times
- Been thanked: 4737 times
- Has thanked: 17458 times
- Been thanked: 16559 times
Re: 26th Oct - Prominence eruption
That’s impressive, SDO showed a lot of activity there at that time!!
- Been thanked: 4908 times
Thanks John for including the explosive-activity occurring in the North-East, which should be even as interesting when it if fully into view over the limb.
Thanks for for sharing your excellent images
- Been thanked: 4302 times
Great images John, and the erupting prom is a major bonus
Also nice to see the results from your DSLR!
