How to Use a ZWO T / T2 Tilter Adapter
rray6
Has thanked: 2 times
Been thanked: 15 times
Post by rray6 »
Does anyone know of any tutorials for the ZWO T / T2 Tilter Adapter? I just got one to help combat those pesky newton rings but there were no instructions with it or on their web site (that I could find). I contacted ZWO support and all they told me was to loosen the small screws and tighten the larger screws (or maybe the opposite). Tried it out today with my ZWO ASI178 (which seems to be a newton rings magnet) and I could not see any difference - rings did not change or go away. So I must not be working it correctly. I haven’t found any useful YouTubes either. Any help would be appreciated.
-Robert
Robert Ray
Last night as I lay in bed looking up at the stars in the sky, I thought to myself -- "Where the heck is the ceiling???"
www.redshift48.com
Lunt LS80 DSII B1800 f/7
WO 132mm f/7
Celestron 9.5 Edge HD f/10
Stellarvue 80mm f/7 Raptor SVR80ST2
WO Z73ii f/5.9 APO
Lunt CaK B1800 Filter and Baader Herschel Wedge (Photo)
PGR Grasshopper 3.0 (ICX687 - mono)
Player One Apollo M-Max IMX432
ZWO ASI178MM and ZWO ASI174MM with filter wheel
SBIG STT8300M
ZWO ASI2600MC-P
Canon 5D Mark IV and Canon Rebel T7i
AP 1200GTO (Permanent) and iOptron CEM60EC and CEM25EC Mounts
Has thanked: 17924 times
Been thanked: 8889 times
Re: How to Use a ZWO T / T2 Tilter Adapter
Join the club Robert!!! I've had one for 2 years now and have never fathomed how to use it. All it does is make the rings worse or go back to original. I can't move the darn thing to make it tilt no matter what I try, or I spend hours just losing the Sun in the telescope and trying to find it again as I have pushed so hard on the screws. I found it wasted so much time in the Sun I abandoned the thing.
Merlin wrote an excellent guide for me, to try and explain it it. My husband understood exactly what he meant and demonstrated it to me how it worked from his instructions. But it is still a mystery to me, I don't get it. My hubby laughed when he saw me nearly throw it in the bin. It may as well be a Rubik's cube puzzle.
If I could find Merlin's fantastic guide on here I would share it, but I don't think I will be able to find it. I kicked myself as I should have saved it.
Sorry for being so negative, but I just don't get it. I use a flat, much quicker and more simple (if not a full disc).
pedro
Has thanked: 14 times
Been thanked: 6684 times
Post by pedro »
The Daystar interference eliminator works like a charm
https://www.astroshop.pt/adaptadores-ba ... t2/p,23247
I use mine all the time with a ZWO ASI174MM and a Quark Cromosphere
It is not cheap but it is better than all the other tilting adaptors.
Check out this video by Daystar
https://www.youtube.com/watch?v=h6GjwHt ... tarFilters
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
This or similar items have never really been necessary for me (for whatever reason) even though some time ago I did have a small NR problem, but overcame that by whatever method - I can't remember.
Perhaps (if not already tried - which most likely you have both tried), off of the scope and preferable with a CALLIPER or MICROMETER, make changes to the tilter-adjustment screws and measure the tilter-platforms/spaces to work-out what it might or should be doing.
That would be my initial-preferred methodology... If it shows signs of tilting, then the snag must be somewhere else ??
Otherwise, as Pedro says, but spending more dosh !!
Rob63
Has thanked: 593 times
Been thanked: 614 times
Post by Rob63 »
I Use the rowan tilt adapter which does the job. I am not sure the ZWO adapter has enough tilt to correct NR's as it's more for deep sky work.
The problem with the Rowan is that you can't adjust tilt in real time, you have to remove-adjust-test until you get there.
The daystar interference eliminator however, can be adjusted in real time but is very expensive for what it is.
Rob.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
Has thanked: 20738 times
Been thanked: 10436 times
I wrote an overview of the topic a few years back:
https://brierleyhillsolar.blogspot.com/ ... rings.html
rray6
Post by rray6 »
Thanks all! Good information.
-Robert
Robert Ray
www.redshift48.com
WO 132mm f/7
WO Z73ii f/5.9 APO
SBIG STT8300M
ZWO ASI2600MC-P
