ImPPG version 0.6.4
GreatAttractor
Has thanked: 762 times
Been thanked: 758 times
ImPPG version 0.6.4
Post by GreatAttractor »
Homepage: https://greatattractor.github.io/imppg/
Download from: https://github.com/GreatAttractor/imppg ... tag/v0.6.4
New features
  • German translation
Enhancements
  • File type filter is remembered when opening and saving images
My software:
My images
Has thanked: 18994 times
Been thanked: 9277 times
Re: ImPPG version 0.6.4
Fantastic!! thank you!
Has thanked: 22126 times
Been thanked: 11279 times
Yes, thanks indeed! :)
Ivan
Has thanked: 3669 times
Been thanked: 2477 times
Post by Ivan »
Thank you very much Filip, this is by far the most magical solar photo editing software. :bow :bow :bow
Ivan
Radon86
Has thanked: 763 times
Been thanked: 665 times
Post by Radon86 »
GreatAttractor wrote: Sat Oct 30, 2021 9:37 pm Homepage: https://greatattractor.github.io/imppg/
New features
Enhancements
Hello Filip,
Thank you very much for supplying us with this free software and the upgrades !!
Any chance of any updated tutorials and advice? I am especially not sure of the number of iterations to use. Can you use say 10 iterations only, and repeat it 5 times instead of 50 iterations for deconvolutions ? Alexandra mentioned she does 500 iterations for some of her processing. Is there a mathematical solution as to the ideal sigma and iterations to use, as at the moment it is all a bit of guess work ?
There are very few videos, even on Youtube, so it is difficult to be sure how to get the best. I have seen yours and the results are very nice.
Many thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
GreatAttractor
Hi Magnus,
Yeah, it's probably high time I made a new (video-)tutorial. As for L-R iterations, my basic advice stands — start with 50 to 70 iterations, though other values may work for you (as for Alexandra).
There might be some way to estimate the optimal parameters automatically, but my preferred approach is fine-tuning by eye for each session — that's the main reason for the GPU mode (so you can select a small image fragment and see L-R results changing in real time).
My software:
My images
Radon86
Post by Radon86 »
Thanks Filip,
I don't seem to be able to get the GPU mode to work, but I will have another try on this.
Magnus
pedro
Has thanked: 15 times
Been thanked: 7131 times
Post by pedro »
Thanks Filip
I use IMPPG to process all my HR images. Greatly appreciated
