The emission line of He1 (known as D3) lies at 14.32A towards the blue from the D1 Sodium line (The doublet D1 and D2)
The intensity of the D3 line is only about 3% above the local continuum.
To make a visible image of the Sun in Helium the continuum image must be subtracted from an image acquired at D3.
According to SimSpec_SHG for the MiniSHG optics, the D3 line should be at 207.43 pixel below the D1 line. When the slit is positioned at the extreme edge of the disk it's possible to see the D3 Helium line in the spectrum close by the D1 Sodium.
The D3 is the bright line and the D1 is the dark absorption line below.
The INTI software allows this offset to be entered (as well as a suitable offset to obtain a continuum image)
Initial trials today (30th Oct) were washed out due to cloud and the limited SER videos obtained were overexposed. Bumma!
They did however verify the methodology and the "best" D3 seemed to be around 207 pixel offset. A couple of Helium "plumes" were easily visible.(about 1 O'clock and six O'clock)
(31st Oct) Another day, another trial.
An unusually bright day. This allowed further trials with the imaging of the Sun in Helium (D3) light.
Less exposure times than previous, used the -207 pixel offset for the D3 and a -180 pixel offset for the background continuum.
Processed using both Doug and Matt's versions Valerie's INTI software.
I think I may be getting close.
Enjoy!
MiniSHG - Sun in Helium D3
- Has thanked: 174 times
- Been thanked: 619 times
Re: MiniSHG - Sun in Helium D3
Wow!! superb!! Helium D3 is almost like an inverted Halpha as the plages are black
- Has thanked: 20813 times
- Been thanked: 10487 times
Very good Ken!
