Here are my magnetometer data from last night here in the UK when a minor CME impacted Earth's magnetic bubble creating beautiful aurora.
There's another one on it's way (stronger, maybe) resulting from the X-class flare on the 28th.
Our very own Mark T was on the ground in Iceland and saw/photographed the resulting light show.
Thanks for looking.
Stu
Minor CME impact 30th/31st October 2021
- Has thanked: 8352 times
- Been thanked: 8102 times
- Has thanked: 17521 times
- Been thanked: 8761 times
Re: Minor CME impact 30th/31st October 2021
Sadly it was a one hit wonder and didn't come up to expectation, probably because we had clear weather tonight will be the main show with rain and gales
- Been thanked: 4299 times
Thanks for showing you data Stuart
If a second blow is to come it will be interesting to see your readings and if it translates to high aurora activity
- Been thanked: 4908 times
Thanks vm Stuart for your excellent data and yes indeed if the big one from AR2887 strikes in our dark-skies, the mind boggles so-far - as to what it will deliver...
Many thanks Alexandra, Brian and Terry.
- Has thanked: 20229 times
- Been thanked: 10109 times
Thanks, Mark. It’s great to see the two aspects of the event ‘side by side’.
