SUN & MOON (20211112)
WEB LINKS:
http://pedroreastrophotography.com/moon_h_alpha.html
http://pedroreastrophotography.com/moon_HR.html
http://pedroreastrophotography.com/sun_moon.html
SUN & MOON (20211112). TV101 F/5.4, Baader Solar Continuum filter, IRPass Filter, PGR GRASSHOPPER 3 GS3-U3-28S4M (SAME SCALE)
MOON (20211112). TEC140 F/7, Baader IRPass filter, ZWO ASI174MM
MOON (20211112). LUNT152 F/6, Baader 35nm H-alpha filter, ZWO ASI174MM
MOON (20211112). LUNT152 F/6, Baader 35nm H-alpha filter, PGR GRASSHOPPER 3 GS3-U3-28S4M, two-pane mosaic
MOON (20211112). TV101 F/5.4, IR-pass filter, PGR GRASSHOPPER 3 GS3-U3-28S4M
MOON (20211112). TEC140 F/7, X5 Powermate, ZWO ASI174MM
MOON (20211112). TEC140 F/7, Baader IRPass filter, X2 Barlow, ZWO ASI174MM
MOON (20211112). LUNT152 F/6, Baader H-alpha 35nm filter, X2 Barlow, PGR GRASSHOPPER 3 GS3-U3-28S4M
Moderator: Montana
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Re: SUN & MOON (20211112)
Wow Pedro !! So many excellent captures of so many parts of the Lunar surface.
Thanks vm for sharing
- pedro
These are quite phenomenal Pedro
I was quite surprised to see a Moon this evening, not seen the sky for so long.
- pedro
- Has thanked: 8559 times
- Been thanked: 8291 times
Beautiful lunar images, Pedro. Lots of lovely details in these. I’m hoping to do some colour imaging over winter with a new camera arriving Dec 25th
- pedro
Thanks Stu
best of luck for your cloud imaging
Pedro Re'
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Pedro,
Nice images there Pedro !
Moon looks very crisp.
I was wondering how a H-alpha filter works on the Moon. Is the Moon a mini Sun ????
Thanks
Magnus
Thanks
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Magnus, it calms the seeing wonderfully and gives a much crisper image. I learned this trick quite early on
- pedro
As Alexandra said it helps to use a IRPass filter (apo refractors) or a 35nm H-alpha filter (achromatic refractors) to image the Moon. The seeing is usually much better in the red part of the spectrum
Pedro Re'
