3D prints to assist with daytime rough polar align
- Has thanked: 235 times
- Been thanked: 584 times
A compass will get you pointed to MAGNETIC north but not true north, nor the celestial pole. It also does not provide altitude information. Sky@Night ran a story about using a smartphone and a star finder app during the day to do rough alignment but that has issues also.
Some looking around on Thingiverse (online library for 3D printing models) and I found two possible aids. Both allow you to mount your cell phone to a Vixen dovetail mount and use the PS Align Pro App to polar align your scope! The first print also allows you to use a red-dot pointer and the PoleMaster camera or a phone so I printed that to try today. The other one only holds a phone BUT gets the phone away from the metal of the mount for perhaps a more accurate magnetometer reading?
I set the rig up in my living room today and even in the house my iPhone 7 seemed to get a good magnetometer reading and allowed me to do a quick and easy alignment. I can't verify how good until I actually get a sunny day or clear night, however. This was crazy easy and if it works better than my Compass - One Star Align - Slew to Sun - Adjust mount - Sync procedure I will be happy.
If you want to give this a try yourself here are the Thingiverse links:
https://www.thingiverse.com/thing:3642636
https://www.thingiverse.com/thing:4133183
- Has thanked: 20435 times
- Been thanked: 10245 times
Re: 3D prints to assist with daytime rough polar align
Nice bit of printing, thanks for sharing!
- Has thanked: 9411 times
- Been thanked: 5570 times
Yes 3D printing makes our life easier. I got a 3D printer two months ago because a friend wanted to motorize his telescope focuser and so we ventured into this new technology.
The best of all is that before printing you have to learn to draw the parts and that is not easy but with time one can learn it.
Below a drawing of the motor holder and an image of this same part printed and working on the telescope.
Now when I need a part I do not need to wait for the metal milling mill because instantly I get my parts (well not instantly but maybe a few hours later)
I print all in PETG plastic. Much better then PLA.
- Has thanked: 42 times
- Been thanked: 1487 times
I've had Polar Scope Align Pro for years and never even realised it had a Daytime mode! Thanks for the "heads up"!
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Rsfoto,rsfoto wrote: ↑Tue Nov 16, 2021 3:38 pm Hi,
I am also trying to learn 3D model creation and printing a .STL file. I thought it might be cheaper if you are only making the occasional part to use a 3D printing service ? I wonder how much a 3D printer would cost, plus materials ? I am trying to get a part for Vixen Polarie but find the postage costs more than the part !!! (shapeways.com).
Thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Hi Magnus,Boso36 wrote: ↑Wed Dec 08, 2021 11:28 amHi Rsfoto,rsfoto wrote: ↑Tue Nov 16, 2021 3:38 pm Hi,
Thanks.
Magnus
Well that depends on where you live and what possibilities you have to get parts. I used to make a lot of custom parts from Aluminum while I was living in Mexico City and had a good machine milling but now in the province there is a problem. On the other side not everything can be made with a 3D printer.
Yes a printer and everything else you need for sure costs much more then a single piece. I am printing now since September 11 and have found out that the printing material is finicky and a lot of trials are necessary until you get the right fit. Plastic has its own life.
On the other side apart from making parts for my telescopes now I find that I need here and there some little parts like hangers, plugs, etc. and so i just sit down, design it and print it and voilá I have the part.
Also you will start printing nonsense for the Grandchildren etc.
OK, I am retired and have time and it is fun to see how the pieces come out and either they are pretty, nonsense or you can really use them for what you designed them.
I just made a big mural and needed some hangers for the wooden frames, so I designed them and they work perfect.
That is a Hubble image
Another part I made is a wire straightener as I am going to build some mobile with hummingbirds I designed and printed ...
- Radon86
Hi Rsfoto,
Yes I see what you mean. You have lots of possible applications of 3D printing, have time and find it interesting - good reason to own a 3D printer. I will try and learn 3D modelling and STL files and see if I can make things of my own quickly and get them to do things without paying ridiculous prices...
Magnus
Magnus
What do you need ?Boso36 wrote: ↑Wed Dec 08, 2021 8:30 pm Hi Rsfoto,
Magnus
- Radon86
Hello Rainer,
I am looking for an adaptor for my VIxen polarie - to fit an ordinary polarscope (EQ3 or EQ5 polarscope)
See this adaptor:
https://www.shapeways.com/product/BTPPG ... or-polarie
The white adaptor is what I could use. However, I cannot see a screw thread on this adaptor, so this would only fit by push-fit and friction.
I could give you some of the dimensions, but it is hard to measure on the Vixen Polarie.
The item could cost 40 USD (item is 23.39 USD but after postage it is 42.71 US Dollars (shipping to UK).
Thanks.
Magnus
See this adaptor:
Thanks.
Magnus
Hi Magnus,
Look here https://www.thingiverse.com/thing:4679141
Now find somebody with a printer near you ... and give a tip to the designer
- Radon86
Dear Rainer,
Thats fantastic ! Thanks very much. So how do I get this .sti file printed out ?
Do I give this to thingiverse or another 3D service ?
Thanks
Magnus
Thanks
Magnus
- Radon86
Hi Rainer,
I found Craftcloud online and have ordered an item which cost 4 gbp plus another small cost for postage, not bad at all.
Thank you !
Magnus
Thank you !
Magnus
