My new Digital spectroheliograph
Telescope 80mm F/6
Collimator 70mm F/6
Grating 1800L/mm 5000A Brazed
ASI174mm
My new short D_SHG
- Has thanked: 174 times
- Been thanked: 619 times
Re: My new short D_SHG
Great result, well done!
I assume the spectrograph is in Littrow configuration.
Which processing software are you using??
Ken
Ken
- The Sun?
- Has thanked: 4 times
- Been thanked: 12 times
Optical path is as follows;
Front red filter 80mm F/6 telescope
Binoviewer 70mm F/6 collimator
Slit width is about 10 microns.
1800L/mm Richardson Grating
Relay lens ASI174MM
Relay lens ASI174MM
- C
- B9C87DCD-D3A1-49C3-BECE-3F5A33527AF5.jpeg (749.65 KiB) Viewed 879 times
- A
- 297596F8-B817-4AAD-A692-4157C8B76806.jpeg (560.77 KiB) Viewed 879 times
- B
B - EFBA418F-E767-4497-8175-0E5AA6549BBB.jpeg (602.83 KiB) Viewed 879 times
- B
Ohnishi,
Thanks for that, appreciate.
It would be worth while trialling the INTI processing software. Much faster than SLiM and does the geometric corrects as well as a "prominence" image.
https://github.com/mattconsidine/Solex_ser_recon_AVI
https://github.com/thelondonsmiths/Solex_ser_recon_EN
regards,
ken
regards,
ken
- The Sun?
Ken,
Thank you for your valuable information.
I was python‘s user long time ago.
I will understand the procedure of the soft.
Next time I will try this.
regards,
Ohnishi
regards,
Ohnishi
- Been thanked: 8907 times
That's an amazing image well done I agree with Merlin, you should try this new software as the results that have been coming out are incredible.
- Has thanked: 20834 times
- Been thanked: 10502 times
Very promising results!
