Some years ago, we did some some experiments with an echelle spectrograph viewtopic.php?f=8&t=8103. We decided to revisit this topic in a more compact setup, as has become the norm these days with recent spectroheliograph designs. The advantage of the echelle spectrometer is the ability to view a large spectral range with high resolution. Our current echelle setup is shown below:
The aperture consists of the 30 micron wide, 3 mm long stainless steel slit masked off to a length of approximately 0.25mm. The image of this aperture is "de-magnified" by a 200mm collimating lens and a 100mm camera lens (both vintage Pentax M42 lenses). The echelle grating is a 25mm x 50mm 79 l/mm 75 degree blaze from Thorlabs. Cross dispersion is created by a Star Analyser 100 and a 3.8 degree prism, both from Paton Hawksley.
The image below is an example using "white light" from an LED flashlight. The camera in this case was a Canon 100D DSLR, which as a large sensor, although a limited spectral range due to its built-in cut-off filters:
The dim line at the bottom is the "un-dispersed" output of the echelle grating. The slanted colour lines above are the "cross-dispersed" output of the Star Analyser (which is a 100 l/mm transmission grating, very strongly blazed in the first order). The purpose of the 3.8 degree prism is to put the output lines more in the middle of the camera sensor.
The next image is of compact florescent bulb, which has a mixture of a few narrow spectral lines and several very broad florescent lines:
Next is a neon bulb which has a large number of narrow lines, mainly in the red and yellow:
After these initial tests, we then turn to sunlight as the light source. We simply let direct sunlight fall onto the aperture. We tried a variety of cameras: the Canon 100D DSLR, a ZWO ASI 174MM and an ASI 224MC. The most pleasing results came with the colour astronomy camera, although the sensor on the 224MC is rather small. We therefore needed to add a 0.5 focal reducer in front of the camera to fit the whole solar spectrum onto a single image:
Visible in this image are the "magnesium triplet" in the green, the "sodium doublet" in the yellow" and H-alpha in red. Above H-alpha are the various infrared absorption lines, mainly due to oxygen in the atmosphere. The echelle grating in this last image was set at a fairly high angle in order to achieve high dispersion and therefore good resolution (in the previous test images, the angle of echelle was set lower, in order to achieve higher intensity).
Echelle spectrograph images -- in colour
- Has thanked: 42 times
- Been thanked: 1485 times
- Has thanked: 173 times
- Been thanked: 615 times
Re: Echelle spectrograph images -- in colour
Doug,
That's a very impressive outcome from your "MiniEchelle".
Well done!!
Well done!!
- Has thanked: 17523 times
- Been thanked: 8763 times
