December Solar Challenge
- Has thanked: 17521 times
- Been thanked: 8763 times
Post an image/sketch of a tree prominence you find on this Sun this December. We all know some proms are called hedgerow or tree proms as they appear to look very much like one. These are quiescent prominences.
For a bit of fun, the one that looks most like a Christmas tree can be SPOD on Christmas day
Let's see all these December trees and hedgerows
- Has thanked: 20229 times
- Been thanked: 10111 times
Re: December Solar Challenge
Nice idea!
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 8352 times
- Been thanked: 8103 times
Here's my effort. Not sure that it's a tree though.
20211202_Ha_Prom by Stuart Green, on Flickr
It's getting more and more difficult at this time of year in the north. Really quite unstable air and less well defined details with the extra air we're having to image through. Anyhow, some Sun is better than none
Good shot there Stu!
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hello Stu,Carbon60 wrote: ↑Thu Dec 02, 2021 12:25 pm Here's my effort. Not sure that it's a tree though.
I was wondering about CaK imaging ? I saw info on the Baader Ca K line filter (1.25 inch filter) on the Baader website. Did not know how that would work with a normal white light set up (I only have Baader solar filters on the front end of a refractor), and no other filters. I dont have a solar wedge or continuum filters yet.
Is the Ca K line filter (looks just like a small filter with threads) about 1.25 inches diameter enough or do you need the full Daystar Ca K module costing over 1000 USD or GBP ? However, I then see Daystar has a Ca H module ? so are they looking at different lines ?
Badder K-line is about 279 GBP for the 2 inch version (less for 1.25 inch) and Daystar Ca H module is about 1070 GBP (+ you need other stuff and ERF)..
Magnus
https://imagesofoursun.wordpress.com/eq ... k-calcium/
Thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Hi Magnus,
I guess this should be discussed on the ‘this is Solarchat’ pages, but to provide a comment here, I would say you get what you pay for and the cheaper Baader filter option will not give a satisfactory result, assuming you’re interested in capturing chromospheric network details. The bandwidth of the Baader K-line is simply not narrow enough. I use a Lunt CaK module with an additional narrowband filter to tighten up the band pass.
You may have just sparked a debate as there are other favourable solutions.
Alexandra/Mark, please can this be moved to the main section?
- Radon86
Hi Stu,Carbon60 wrote: ↑Thu Dec 09, 2021 7:10 pm Hi Magnus,
Thanks for your input. I realised this Ca K imaging is too advanced for me at present. I have to do a lot of work in my day time job for the winter months, so will not be able to digest much, so apologies for taking up your time.
Magnus.
just a note to me so I can find these again later
viewtopic.php?f=4&t=34173
viewtopic.php?f=4&t=34187
Hi:
Here is my X´mas tree looking version of a protuberance.
Thanks for looking, it was taken with a 102mm f/7 Stellarvue working at f/28 with a Baader 4X telecentric plus an old Daystar T-Scanner 0.45A° Ha filter.
- pedro
- Has thanked: 14 times
- Been thanked: 6556 times
Here is my contribution
SUN (20211211) H-alpha. LUNT152, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20211213) H-alpha (09:30 UTC). TV101 F/5.4, DS SM90II/SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
Pedro Re'
- Martin_S
- Has thanked: 975 times
- Been thanked: 2987 times
Sorry folks, epic fail, my tree fell over.
Martin
Martin
H alpha : ,Skywatcher 100mm F10 open frame refractor, a tilted 2" 7nm H-alpha filter as a sub energy rejection filter, Baader TZ4 telecentric focal extender, Player One energy rejection filter, Combo Quark Chromosphere, Naked PST etalon for double stacking, ASI74mm camera
Martin_
It looks like you did not water the tree.
Best regards, here I put another tree, hope it does not fall over.
- Has thanked: 2406 times
- Been thanked: 4737 times
I'm back after about three weeks of renovating our house.
So much cloud in this period that it is impossible for me to see the sun...
I hope you see a kind of a tree in the older image, that's not a December sun.
Great images from everyone here!
- Been thanked: 4908 times
Welcome back from the renovations Maurits and an excellent image.
Thanks vm
Thanks vm
- Has thanked: 17458 times
- Been thanked: 16550 times
The solar wind blew over the solar Christmas tree!
Thanks Alexandra. I hope to do it again this coming weekend if the weather allows and it isn’t too cold.
- Has thanked: 24 times
- Been thanked: 133 times
is of December 2021 the my first Sun H-Alfa image and December is also the month I was born :-)
15.12.2021, matera (ITA)
Takahashi FC100DL, Daystar Quark Cromosphere, ASI 178MM, Tecnosky reducer 0,5x.
AsiStudio (20sec), AstroSurface
