Still working with filters - trying to find the Holy Grail to suppress the parasitic light.
Some interesting filaments visible with a couple of proms. Both in CaK and CaH.
I did an "inverted" CaK to better show the fluffy "flocculation clouds" visible in CaK.
I misread G E Hale's earlier description from 1929 when he said "....that a distinctive term should be adopted, and I now propose the name flocculi for the regions on the Sun's disk which are shown only on photographs made with the spectroheliography" and believed that these "clouds" were the flocculation he was talking about. He was actually referring to the brighter lines between these formations.....
Enjoy!
CaK and CaH 11Dec2021
- Has thanked: 174 times
- Been thanked: 619 times
- Has thanked: 8559 times
- Been thanked: 8297 times
Re: CaK and CaH 11Dec2021
Great images, Ken. Are you willing to spill the beans on the filters you’re using (maybe you have done already in earlier posts)? I’m guessing they’re expensive given their tight bandpass.
Stu,
The MiniSHG has a bandwidth of about 0.1A this allows the resolution of all the detail available.
The filters I’m trying are effectively acting as energy rejection filters for the CaK wavelength.
I’m waiting on a W47 filter, in the meantime I’m using a combo of a 0.9ND Baader (12.5% transmission) and an Astronomik UV-IR filter.
So, not expensive filters, The performance comes from the MiniSHG.
- Been thanked: 8907 times
These are incredible Ken and the colour is absolutely fabulous if I were clever enough or could make a miniSHG as part of a group effort I would definitely do so
- Has thanked: 20828 times
- Been thanked: 10499 times
These are very impressive results again Ken. How much of an issue is parasitic light?
Certainly interesting results Ken given the quiet Sun, which yours have shown the detail
Thanks vm
Thanks vm
- Has thanked: 9327 times
- Been thanked: 6163 times
- Been thanked: 4434 times
Excellent results Ken
Mark,
We're not a 100% sure where it's coming from. Could be an artefact of the processing software.
The end result is a veil of light over the image which reduces clarity and definition.
In my case worse in CaK and hardly noticeable in H alpha.
Onwards and upwards.
