150mm Solar Newtonian first light
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Here is my first solar newtonian that I converted from an old 150mm f/8 that was well past it's use by date. I was hoping to build a Serrurier truss, but didn't have enough parts on hand as we are in lockdown and couldn't go out. The primary mirror was left in hydrochloric acid for 3 days to remove the coating.I did a quick collimation to test everything , then took a six pane mosaic at prime focus with my ASI174 mm. The seeing was not good enough for any high res imaging as the atmosphere was on the boil.
Martin
Martin
- Has thanked: 9414 times
- Been thanked: 5578 times
Re: 150mm Solar Newtonian first light
Hi Martin,
Very nice. So taking off the coating makes the mirror work in the same way as a Herschel wedge ?
Thanks Rainer
Thanks Rainer
- Martin_S
Hi Rainer, it sure does, I'm impressed with the results , it outperforms my 150 maksutov as the air flows through the truss so there are no tube currents etc.
Martin
Martin
- Has thanked: 42 times
- Been thanked: 1487 times
Ferric Chloride will etch the aluminium coating off of a mirror in three hours or so. I believe it is also a bit less nasty to dispose of (mix with bicarbonate of soda to neutralise it). See my post from a few years ago: viewtopic.php?f=9&t=11814&p=117999&hilit=ferric#p117999 and a more recent one by Bart viewtopic.php?f=9&t=25766The primary mirror was left in hydrochloric acid for 3 days to remove the coating
- Martin_S
I tried getting some ferric chloride locally, but could only get it on Ebay or mail order. I just used some of my pool acid, and added some bicarbonate of soda to neutralise it. Thanks for the links, they are an interesting read.thesmiths wrote: ↑Mon Dec 20, 2021 11:50 pmFerric Chloride will etch the aluminium coating off of a mirror in three hours or so. I believe it is also a bit less nasty to dispose of (mix with bicarbonate of soda to neutralise it). See my post from a few years ago: viewtopic.php?f=9&t=11814&p=117999&hilit=ferric#p117999 and a more recent one by Bart viewtopic.php?f=9&t=25766The primary mirror was left in hydrochloric acid for 3 days to remove the coating
Martin
- Been thanked: 10247 times
A great scope mod there Martin! Thanks for sharing.
- Martin_S
Thanks Mark, Have a great Christmas and new year,
Martin
Martin
Thanks Martin, you too.
I've always liked the idea of a solar newton.
My recommendation for a scope from which to build a solar Newtonian would be the "Sky-Watcher Heritage-150P Flextube Dobsonian Telescope". The brilliant thing about the Flextube design is you can shorten the length easily to increase the back focus (the secondary mirror is oversized enough to accommodate this). It also has quite a nice 3-arm secondary mirror spider support. The mirror is parabolic (in theory better than spherical). It has a Vixen dovetail on the side so it is easy to attach to all kinds of mounts. The included Dobsonian mount is actually very useful and can be used with many other telescopes. I based my solar Newtonian on the 130P Flextube (because it was so cheap), but if I had to do it again, I would use the 150P.
The focal length is 750mm (f5) so is short enough to get a full disk on a large sensor, and you can use a magnifier to get up to f10. In theory, you can use a (homebrew) CaK filter, although seeing will be an issue with such a large aperture. Collimation is also a bit tricky and I think poor collimation is the reason why some solar Newtonians don't live up to expectations.
If you do get one of the Flextubes, don't forget the Teflon tape for the rotating focuser (otherwise it's a bit too loose).
- Martin_S
These scopes are amazing for the price, they get snapped up pretty quick on the used market over here.
Two weeks ago I bought an old EQ3 pro for $100 with a 150mm f8 OTA that also included a big box of accessories ,eyepiece's, battery and charger .
I only wanted the tripod for my AZGTi , so I was stuck with all the other stuff.
I rebuilt the mount, it works fine and converted the OTA into a solar Newtonian. this must be the bargain of the year for me.
Martin
- OlegLviv
- Has thanked: 881 times
- Been thanked: 907 times
Hello! Great job!
I saw this telescope in the book http://solar-astronomy-book.com/
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- Martin_S
Interesting question David. Maybe a PST mod or a quark . I'm not sure what the illumination would be for Ha .
Martin
- Has thanked: 696 times
- Been thanked: 648 times
Thank you for this thread - I just found it & its got my mind whirring. Before lockdown I was taking ATM classes to make a 6" newtonian. The mirror is almost finished but not aluminised - and I no longer need a 6" newt for night-time - so a seed has truly been planted! Is there a good book I can read to brush up on this (that solar-astronomy-book.com) or would the best thing be to soak up all the Solar Newtonian pages here? Thanks again!
- Martin_S
Hi Vineyard , thank you for your comment. The Solar Astronomy book is an essential reference for all aspects of solar astronomy. I would advise you to do as much research on a 150mm solar Newtonian as possible. A 150mm telescope is a great instrument but you must familiarise yourself with all the safety requirements associated with an instrument this size and strictly adhere to them.
A 150mm solar scope's performance is very dependant on atmospheric conditions, my 102 f10 refractor gets more use than the 150mm Newtonian as I am in the sub tropics at sea level about half a Kilometre from the ocean. I hope this has helped with your prospective white light endeavour.
Martin
Martin
