January Solar Challenge
- Has thanked: 17458 times
- Been thanked: 16562 times
Re: January Solar Challenge
Very nice!! Imaging is always a “ work in progress” it seems.
- Has thanked: 8355 times
- Been thanked: 8103 times
I know this doesn't work for everyone, but here's a 'stereoscopic' view of the Sun at Perihelion and Aphelion. The trick is to get the images scaled on your screen to align with your left and right eye and then stare through the images so that your brain merges them together (don't cross your eyes- this is a common mistake and is the wrong way to view these types of images). Let your eyes relax, stare through and your brain will do the rest.
Anyhow, what you should see is the aphelion disk fall away to the distance with the perihelion disk in the foreground.
Intended as a bit of fun and a novel way to show the effect. I hope it works for you.
- Ivan
- Has thanked: 3461 times
- Been thanked: 2250 times
Stu, I failed. Although I can easily see images in stereometric pictures with two white dots. In any case, both the photo and the idea are excellent!
Ivan
Ivan
Not to worry, Ivan. It can be tricky to see the full effect. It seems to work best on a smartphone, sideways on, as the image scale seems better suited to the eyes.
Thanks for trying
