Venus from Friday Jan 7
Lets brighten up peoples live with all those lovely pictures of the world around us!
Moderator: Montana
KMH
Has thanked: 658 times
Been thanked: 766 times
Post by KMH »
I was able to image Venus again on Friday, about 27-28 hours before conjunction, when it was about 5.5 degrees from the sun. The seeing was below average, but quite a bit better than on Wednesday. All were taken with an Explore Scientific 127ED refractor and no cameras were melted (!).
#1 2.5x Powermate and Celestron Skyris 445 color camera;
#2 4x Powermate with mono Grasshopper camera and Baader near IR (>685nm) filter;
#3 4x Powermate with Grasshopper and nIR filter - longer exposure and inverted to better see the partial ring caused by atmospheric (Venus') refraction.
There is not a complete ring - it's too far from the sun for that. It looks like about 270 degrees. Note also the brighter area of the crescent at about the 5 o'clock position and the asymmetry of the refracted ring. I've seen these reported by others so they are apparently real - I guess indicating non-uniformities in Venus' clouds??
Kevin
Has thanked: 17925 times
Been thanked: 8894 times
Re: Venus from Friday Jan 7
Wow!! superb! I really like the inverted as it shows the crescent better, well done :bow :hamster:
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Three excellent captures of Venus Kevin.
The refracted ring really does show very well and any Venusian atmospheric-clouds would likely be the cause...
Thanks for sharing
Has thanked: 20757 times
Been thanked: 10442 times
Very good indeed! Thanks for sharing!
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Excellent captures Kevin :bow
