"Thanks" to the current bad weather, I spent some time testing another Coronado SM-40 with the Ha lamp
This is the second one I tested. The first one was 0.74 FWHM, but this second one is 0.95 A FWHM. It 0.9 A away from the center of Ha at normal incidence.
If I am not mistaken, the SM-40 was supposed to have a FWHM < 0.7 A ?
When the Sun is back (if ever ...) I try and test the BF 5 with the spectro.
More results here :
http://astrosurf.com/viladrich/astro/in ... -40_2.html
Clear skies
Measurements of a Coronado SM-40 Ha filter and BF5 - Ha lamp
- Been thanked: 2725 times
- Has thanked: 20813 times
- Been thanked: 10484 times
Re: Measurements of a Coronado SM-40 Ha filter - Ha lamp
Thanks for the info Christian. This second etalon is not the best
Hello,
I now have tested the BF5 (more precisally the whole BF5 diagonal).
The FWHM is 6.9 A. The offset from Ha is +1.5 A, which is not a big deal. This is a 2-cavity filter.
http://astrosurf.com/viladrich/astro/in ... an2022.jpg
Thanks Christian, all good information!
Re: Measurements of a Coronado SM-40 Ha filter and BF5 - Ha lamp
Just to say I put some more results in the following webpage:
I am afraid it's quite technical. The new stuff (test in collimated light) is about the mapping of the CWL drift over the aperture of the etalon. In other words, it is about assessing the uniformity (or not) of etalons.
Given the low altitude of the Sun in winter, I have two more months to work on these. Then, I go back to imaging ;-)
Very interesting thanks Christian, I will flag this for my weekend read
- Bob Yoesle
- Has thanked: 541 times
- Been thanked: 811 times
Just want to add to Christian's work that etalon tuning and uniformity using a collimator can also be observed visually by having the etalon/telescope system aimed at the Sun and removing the eyepiece (keeping the BF in place) and viewing the etalon "surface" directly. This also represents illuminating the etalon with collimated light (~ f109). Once the etalon is on-band it will have the most uniform and brightest appearance obtainable (as in the middle figure shown by Christian for the SM40). Any variation in brightness represents a variation in the CWL of that area of the etalon - variation in etalon gap spacing.
Here's a simulation of what tuning an etalon to be on-band generally looks like going from left to right. I have successfully used this method to perfect the tuning of both single a double stacked front and front/internal etalon systems.
More on this topic can be found here.
