Sun in Ha and CaK Jan 20th 2022
- Has thanked: 8355 times
- Been thanked: 8103 times
Another blue sky day here, but yet again poor seeing. Anyhow, here are my FDs in CaK and Ha and a couple of closer views in Ha of a magnetically disturbed region within the southern chromosphere and some post flare loops on the western edge from AR2929, which produced an M5.5 magnitude flare earlier this morning (06:01 UT).
First up are the calcium disks:
20220120_CaK_FD_Mono by Stuart Green, on Flickr
20220120_CaK_FD_colour by Stuart Green, on Flickr
....and the Ha disks (albeit a bit patchy)
20220120_Ha_FD_Mono by Stuart Green, on Flickr
20220120_Ha_FD_colour by Stuart Green, on Flickr
20220120_Ha_FD_Inverted_Mono by Stuart Green, on Flickr
Finally the closer views, including the loops, which are more or less edge on, although they are somewhat faint and not very sharp because of the conditions.
20220120_Ha_AR by Stuart Green, on Flickr
20220120_Ha_Post Flare Loops by Stuart Green, on Flickr
The forecast over the coming days is not good for solar viewing, so that's my lot for a little while.
Thanks for looking.
Thanks for looking.
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Re: Sun in Ha and CaK Jan 20th 2022
Nice set of images, Stu.
Sky is clear this morning in Wisconsin, but the temp outside is zero degrees F. A good day to read a few chapters in Viladrich et al "Solar Astronomy."
Jordan
Jordan
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
- Has thanked: 9074 times
- Been thanked: 5977 times
Thank you for the beautiful views of the sun, Stu, showing the new AR. Snowing here, a gray day.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Stu, I've just finished a session and similar views to me. There were some lovely proms in Calcium II K too. Screenshot of one of the cak proms I captured today too. Thanks for sharing.
- Screenshot (394).png (442.75 KiB) Viewed 918 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 3292 times
- Been thanked: 1879 times
Thanks for the images.
My seeing was not good either.
Proms pretty much as you imaged.
Like Rainier your bright area on the SE is burnt out. For me there was a double spot, one small. And then two bright areas with a smaller spot at the bottom.
You show more contrast on the surface than I could see.
Nice to see the dim loops.
Cheers. Andrew.
Cheers. Andrew.
- rigel123
- Has thanked: 8189 times
- Been thanked: 8425 times
Those are gorgeous shots Stu! Your seeing was definitely better than mine!
- Has thanked: 20240 times
- Been thanked: 10113 times
Very nice Stu! Those bands of activity really are getting quite prominent now.
- Has thanked: 17524 times
- Been thanked: 8763 times
Almost missed this one Stuart, I'm glad I didn't, what a Halpha full disc!!!! and post flare loops!!!
Thank you, everyone. After a long period of the Sun being quite blank, it’s so interesting to see the activity level increasing as cycle 25 continues to evolve and it’s such a privilege to be able to image it.
- Been thanked: 4302 times
Superb images Stuart, and the loop prom on the western limb is really nice to see...well done
- Has thanked: 9243 times
- Been thanked: 5503 times
Hi Stuart,
Excellent images
Excellent images
- Been thanked: 4883 times
Many thanks, Brian, Rainer and Eric.
- Has thanked: 6161 times
- Been thanked: 7097 times
- Has thanked: 17458 times
- Been thanked: 16559 times
Stu!
I don't know how I missed these! Very nice. My eyes again are drawn to your CaK images. Why am I drawn to something I don't have? :-(
You got post flare loops in Ha too!
Hi Stuart...
Congrats on having the image of the post flare loops chosen as the SPoD...well deserved
