spent some time on making a doppler image of an H-Alfa capture this morning with the Sol'Ex SHG. (before clouds spoiled the session)
Images generated with +3 /-3 pixel shift (0.59A) and then combined in a color image.
Maybe still need to work a bit on the technique, but not too bad ...
Paul
Doppler Image Jan 30
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
- Has thanked: 17523 times
- Been thanked: 8763 times
Re: Doppler Ilage Jan 30
Wow!! I like it I take it that red is red shift and blue is blue shift?
- PDB
Re: Doppler Image Jan 30
Hi Alexandra;
yes it is supposed to be like that, unless I accidentally switched colors. I took +3 px for red and -3px for blue.
The green channel is created by averiging the blue and red one.
Rgrds,
Paul
Rgrds,
Paul
- Has thanked: 20240 times
- Been thanked: 10113 times
Looks great Paul!
- Has thanked: 9243 times
- Been thanked: 5503 times
Hi Paul,
Interesting but I have to ask. What does this show ? I have seen the Dopplergramm posted in the SDO website but it looks completely different.
Thanks Rainer
Thanks Rainer
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Paul.
Nice dopplergram but I agree with Rainer that your version is different from the standard type of dopplergram from SDO. There are probably two reasons for this. One reason for the difference lies in your use of the green channel which contains the velocity averaged information whereas a true dopplergram simply uses the difference (red minus blue or vice versa). You are actually presenting a true dopplergram superimposed on a conventional image - which can be useful for correlating velocity fields with actual feature locations. The other reason is that your dopplergram is created in H alpha (chromospheric) while the SDO image (on the NASA site) is likely using a photospheric line (although I can’t find the information on the site).
Peter
Peter
- PDB
Thank you for the comments Peter. I did several tries (also with 2 channels) but could not get good results (probably combining the wrong way) So I switched to what is descrived on the Sol'Ex page from Christian Buil) using an average of the 2 channels as green channel.
Paul
Paul
- p_zetner
Hi Paul.
You’ve probably done this already, but why not try different pixel shifts and see if you can intensify the structure in the dopplergram? As you progress outwards from line centre you are “tuning” to faster velocities and these higher velocities might prevail near the active region.
Peter
Peter
- p_zetner
I’d recommend this paper, described by many as groundbreaking. It’s old and deals with film capture but it is relatively straightforward to “translate” into digital spectroheliography.
Velocity Fields in the Solar Atmosphere. I.
Preliminary Report.
Leighton, Robert B. ; Noyes, Robert W. ; Simon, George W.
1962ApJ...135..474L
https://ui.adsabs.harvard.edu/abs/1962A ... L/abstract
Regards.
Peter
Preliminary Report.
1962ApJ...135..474L
Regards.
Peter
