The GIF shows the Proms as we move from the outer K1v (blue) wing, through the K2v then the core at K3 and out into the red wing. (There are some compression artefacts due to the reduction in the file size )
The distance from K1v to K1r is approx 1A
The individual images (unprocessed) show the file name - the end digits are the pixel offset from the CWL (K3)
3 = 0.25A, 7 = 0.55A and 17 = 1.33A
The profile graph shows the overview. Also added the probable FWHM Lunt filter curve for comparison.
The Proms are much more visible in and around K3 and become more difficult out in the wings (K1v17)
Prom visibility across the CaK bandwidth
Moderator: marktownley
- Has thanked: 174 times
- Been thanked: 619 times
- Has thanked: 3317 times
- Been thanked: 1907 times
Re: Prom visibility across the CaK bandwidth
Great work there Ken.
When I get my observatory re-built \i would like to do the same.
Cheers. Andrew.
Cheers. Andrew.
Nice work Ken looks like K3 is the best for proms
- Has thanked: 8559 times
- Been thanked: 8290 times
Very interesting, Ken. Nice demo.
- Has thanked: 9319 times
- Been thanked: 6157 times
- Been thanked: 4427 times
Great post Ken...thanks for the details
- Been thanked: 4980 times
Ken:
Very interesting demonstration.
Thanks for sharing all that info.
Best wishes.
Best wishes.
- Been thanked: 10489 times
I'm going to make a copy of this in the reference library.
