February Solar Challenge
- Has thanked: 17521 times
- Been thanked: 8763 times
This month lets look carefully at large active regions in hydrogen alpha.
I was first brought to the attention of magnetic bipolar regions (MBR) by Kevin Kilburn from the Manchester Astronomical Society. He had done a small study and published it in the BAA Journal in 2017 https://britastro.org/journal_item/10336
What you have to look for is the large area of magnetic disturbance in the mottles surrounding the sunspots. These equate to the region of magnetic polarity. Sometimes it is easier to see it when slightly off band. The mottles follow the field lines and look like flower petals. The magnetic influence is larger surrounding some spots than others.
I've enclosed a couple of images from Eric Roel (I hope he doesn't mind) and SDO HMI Magnetogram to describe what I mean.
From memory I think White is North and South is black.
Something to observe, sketch and image and above all, to think about and not overlook.
- Has thanked: 20229 times
- Been thanked: 10111 times
Re: February Solar Challenge
Good idea!
- nicspenceryork
- Has thanked: 5778 times
- Been thanked: 1235 times
Love these monthly challenges as I learn so much from seeing the posts and discussion, thank you… hoping the clouds clear (don’t we all!) and I can join in too!
Alexandra:
Very good idea, BTW thank you for using one of my images, if they help please use them whenever you need.
- Has thanked: 1640 times
- Been thanked: 878 times
- DanielD
- Oh, I get it now!
- Has thanked: 47 times
- Been thanked: 55 times
Great to learn something new! So are these bipolar magnetic regions always present round sunspots, as long as you seee the disturbed mottles that follow the magnetic field?
Lunt LS60MT Single Stack
ZWO ASI290MM
2x Tele Vue Barlow
ZWO ASI290MM
2x Tele Vue Barlow
- Has thanked: 8352 times
- Been thanked: 8103 times
Good challenge, Alexandra.
It’s also interesting to note that the magnetic polarity of the leading sunspot is opposite between northern and southern hemispheres
Daniel, I think you will only see a large disturbance in the mottles if there is a strong magnetic field present to draw them all one way. Remember that a mottle follows a weak field line anyway but in the presence of a strong field (near a sunspot) they all orientate that way. In Halpha you can visually see the strength of the field around the sunspot gauging by the size of influence away from the sunspot.
I'm no expert in this though, but it gives you something to research further and take note of when out observing
- Has thanked: 17458 times
- Been thanked: 16550 times
Alexandra,
I have mentioned the disturbed field of spicule mottles near active regions numerous times in my viewing of them. In addition to being easily imaged they can be seen visually as well. It is truly a good field of study since electro-magnetism largely drives the Sun coming in only in second to it's nuclear fusion process in the core. This is something I need to get into more and could help drive me to image more and to save more SDO HMI magnetogram images to my records.
Two questions
1. Can amateurs do magnetograms without relying on professional image data?
2. Where can we find magnetic maps showing the field lines on the sun and around active regions on any given day?
I have not been able to find any current field line charts/images/maps anywhere. Magnetograms from various sources are easy to find.
Thanks and good idea!
Two questions
- Been thanked: 4299 times
Hi all...
The field lines around the active regions have always fascinated me, and been trying to find a way to enhance them. I applied an Emboss filter to a couple of my Feb 5th images using Photoshop...does this count towards the challenge
Brian,
I can certainly see a large patch of disturbance in both. And what appears to be a filament. Inverted images should show the magnetic induced disturbances very well also.
I was wondering if this filter is just adding a textured appearance to the original image, rather than outlining any magnetic field lines. It is still only a 2-D enhancement of the lines if any at all.
Brian,
It does seem to show something there marking the positions of where the disturbed area should be. The textured look reminds me of the textured ceilings in some houses! :-)
James, LOL...I should take a pic of out living room ceiling
MapleRidge wrote: ↑Mon Feb 07, 2022 1:22 am James, LOL...I should take a pic of out living room ceiling
Brian, I really like how that turned out, it really emphasises the magnetic disturbance
James, you are looking at exactly the right feature.
1. Yes, look at the Halpha mottles
2. To access the field lines use this site http://suntoday.lmsal.com/suntoday/?sun ... 2022-02-07
Use the HMI Magnetogram (obviously) and click on the PFSS to get the lines
Alexandra...
Good to know that it has some validity in tracing the magnetic field lines
Montana wrote: ↑Mon Feb 07, 2022 12:04 pm Brian, I really like how that turned out, it really emphasises the magnetic disturbance
I have Imsal saved in my bookmarks and use it often. Somehow I overlooked this feature! Thank you Alexandra. I will find this useful especially when I start imaging more often where I can compare what my images show to the magnetogram. I can study this with GONG Ha images too but I had rather use my own.
Does anyone publish an image regularly of these field lines over an Ha image?
I am thinking about joining the BAA.
Thank You.
James, definitely join the BAA, submitting all your daily observations would be a fantastic resource for the future. You never know, in 200 years time someone could be using your data for research
Just make sure you say you found out about the BAA from Solarchat
Will do Alexandra! It's certainly worth consideration. I do save all of my visual data along with images of my own and from others including some from SolarChat as well as from GONG and SDO.
- daniele_bonfiglio
- Has thanked: 586 times
- Been thanked: 576 times
Dear all,
this is my attempt for the challenge. The H-alpha image is mine, the magnetogram with field lines is from the link sent by Alexandra. Both are from the 2nd of February, but mine was taken several ours earlier than the magnetogram, and this is the reason for the mismatch in the Solar limb.
Alexandra, do you know if there is a way to select a given time for the images from "your" website?
Best, Daniele
Best, Daniele
Solar scopes: Daystar Solar Scout DS 60/930
80mm f6 achromatic refractor with Daystar Quark from the Solar Scout
Scope: Skywatcher Maksutov-Cassegrain 127/1500
Mount: Skywatcher AZ-GTi
Camera: Fujifilm X-T30
Instagram: @daniele.bonfiglio.astropics
That's terrific!!!! I see what you mean though in the fact the active region has moved closer to the limb.
I found that they only seem to produce one image per day with the field lines
They also produce the PFSS data on the HMI Magnetogram on SDO https://sdo.gsfc.nasa.gov/data/
Maybe it is possible to work out a data download at a time? I've never tried.
- daniele_bonfiglio
Dear Alexandra,
thank you very much for the suggestion about the SDO website. Indeed by browsing the archive it is possible to find quite a few images with PFSS data... I have found a couple of them for a time very close to my capture (just half an hour later). If I have time today, I will produce a new animation with a comparison of my image!
https://sdo.gsfc.nasa.gov/assets/img/br ... IBpfss.jpg (this is a standard magnetogram)
https://sdo.gsfc.nasa.gov/assets/img/br ... 71pfss.jpg (this one is wonderful with the 171 Angstrom image together with a color magnetogram and the field lines! it is actually possible to compare how the plasma emitting at 171 Angstrom follows field lines with field lines computed from the magnetogram!)
- daniele_bonfiglio
And here it is!
Superposition of my H-alpha image with the composite SDO image https://sdo.gsfc.nasa.gov/assets/img/br ... 71pfss.jpg
The superposition is made with Photoshop putting the SDO image on the top layer, with the "lighten" blending option.
Best, Daniele
Best, Daniele
Daniele,
Very nice job!! What date are the two images used?
I have tried to no avail to find an ha image that shows the field lines.
- daniele_bonfiglio
Dear James,DeepSolar64 wrote: ↑Fri Feb 18, 2022 2:47 pm Daniele,
Thank you very much!
Indeed, I don't think there are ha images on the SDO website.
The image above is a composite I made with Photoshop of my ha image attached below and this one from the SDO: https://sdo.gsfc.nasa.gov/assets/img/br ... 71pfss.jpg
Best, Daniele
- Been thanked: 4908 times
The SWPC SYNOPTIC MAP explain the magnetic regions as shown on https://sdo.gsfc.nasa.gov/assets/img/br ... 71pfss.jpg
as just submitted above
- = negative magnetic polarity regions within the dotted lines
+ = positive magnetic polarity regions within the dotted lines
- 18-2-2022 1341z SWPC - synoptic-map.jpg (971.66 KiB) Viewed 560 times
SDO image of...
- 20220202_105210_4096_HMI171pfss.jpg (714.72 KiB) Viewed 558 times
- rigel123
- Has thanked: 8189 times
- Been thanked: 8423 times
That is great!
