Weak CME Impact 1st-2nd Feb 2022-Updated
- Has thanked: 8559 times
- Been thanked: 8290 times
The anticipated CME arrived overnight (UT) producing only a weak geomagnetic effect (not even a G1 storm) and no significant aurora. Nevertheless, it was detected on my magnetometer here in the NW of England, as shown below.
I've provided both the declination plot (top) and my usual rate of change plot. I tend to use the latter for long duration plots >2-3 days to remove the influence of minor temperature changes at the sensor buried underground. It's shown here as a means of comparison with previous plots.
It looks like things have settled down again for the time being.
Thanks for looking.
Thanks for looking.
Re: Weak CME Impact 1st-2nd Feb 2022
This is weak, your best was nearly up to 15
Oh well, a little breath of solar wind
Ha..ha....yes. 15 is the record so far. Let's hope for more over the coming months.
Thanks Stu for the update from the Behemoth.
Should we call this as "Damp Squid" of the event
- Been thanked: 4427 times
As weak as it was, it is good to see you got a record of it
- Been thanked: 10488 times
A good capture as always Stu
Many thanks, Terry, Brian and Mark.
Updated data showing a second wave of geomagnetic unrest in the wake of the original impact.
Re: Weak CME Impact 1st-2nd Feb 2022-Updated
What does it mean when one goes and up and the other goes down? is that opposite polarity?
Nice addition Stu
Many thanks, Terry, Alexandra and Mark.
Hi Alexandra,
The best way to think of it is to imagine holding a compass, facing north. During a geomagnetic event the compass needle will move either clockwise to the west, or anti-clockwise to the east (very slightly, as the effect is small). The angle of movement away from north in either direction is called the declination. My magnetometer is really just a declinometer, which measures this variation in declination with east being up the scale (positive declination) and west down the scale (negative declination). The degree of change, the rate of change and the direction of change during a storm depends on the magnetic polarity and intensity of the solar wind, or CME, hitting Earth. Southerly magnetically oriented solar wind, for example, produces a stronger effect than northerly magnetically oriented wind because the field lines carried within the solar plasma can link up with Earth’s magnetic field lines, thereby providing an easy route for energetic particles to enter a get directed to Earth’s poles, producing the Aurora.
Exactly how much and in which direction the declination changes I think is quite a complex phenomenon involving plasma physics and has to do with how the solar wind induces ring currents within the magnetosphere and ionosphere environments. These ring currents are what induce the changes in declination.
Rather long winded, but if you want some bedtime reading for more detail on the subject, here’s an article that might be of interest.
https://link.springer.com/article/10.1 ... 017-0412-2
