Dear all,
I think I was lucky enough to capture a significant flare for my first time.
I still have to post process the photos I took during almost one hour from 10.10 UT on the 2nd of February.
This is just a first processing from a two minutes interval around 10.20 UT when, according to the GONG H alpha images there was a flare on this active region, the 12939. The GOES X ray flux data also shows a peak on the same time.
In the next days I will post more pictures and hopefully a timelapse showing the flare.
My instrumentation is a Daystar Solar Scout DS 60/930 on a Skywatcher AZ-GTi mount. As a camera I use my Fujifilm X-T30 mirrorless. I do burtst of jpeg shots at around 10 FPS (I know this will sound ridiculously low to most of you but this is the best I can do right now and it's not so bad given the small diameter of my scope, and I prefer this to undersampled videos) and I correct them for field rotation with a home made script using the image magick engine. I stack the frames with Planetary System Stacker (1.5x drizzle to reach the optimal sampling), and process them with ImPPG and finally Photoshop.
Best Daniele
Possible flare from the 2nd of February?
- daniele_bonfiglio
- Has thanked: 586 times
- Been thanked: 576 times
Solar scopes: Daystar Solar Scout DS 60/930
80mm f6 achromatic refractor with Daystar Quark from the Solar Scout
Scope: Skywatcher Maksutov-Cassegrain 127/1500
Mount: Skywatcher AZ-GTi
Camera: Fujifilm X-T30
Instagram: @daniele.bonfiglio.astropics
- Has thanked: 20240 times
- Been thanked: 10116 times
Re: Possible flare from the 2nd of February?
That came out nice Daniele. I image my full disks at 9fps.
- Been thanked: 4908 times
Yes Daniele, you have very-well captured the flare, so well done.
Thanks vm
Thanks vm
- rigel123
- Has thanked: 8189 times
- Been thanked: 8425 times
Nice catch!
- Has thanked: 17526 times
- Been thanked: 8763 times
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Mark,marktownley wrote: ↑Sun Feb 06, 2022 5:48 pm That came out nice Daniele. I image my full disks at 9fps.
Interesting to know you can get away with only 9fps.
Do you know how to download SDO images automatically ? I am thinking of automating processes to show flares from the NASA SDO site. But it is tedious to download each image. Also it is difficult to get the images in sequence and to know which image to download as it is not in a regular pattern.
Does anyone done anything like that. I am thinking of cropping a section of the sun and then processing it to show a long time lapse of the flares/proms etc.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Radon86
Hi Daniele,
I was working out my focal reducer on my Quark at about the same time as you, and I think I got a flare as well but I have not had the time to process it properly, I don't think my 2nd Feb is supersaturated so may have just missed it. My images from 4th Feb do show a few with possible white outs and flares ! (also testing a focal reducer).
I don't know that you can affect sampling by drizzling, I never knew that. That could be the answer to some of my problems.
Maybe I will check out Planetary System Stacker (was that by the same guy who wrote Moon Panorama Maker ??).
Where are you based Daniele ? I have a Skywatcher EQ3 Pro mount, may be selling this in the future.
Magnus
Magnus
- daniele_bonfiglio
Hi Magnus, first of all sorry for the late reply!Boso36 wrote: ↑Mon Feb 07, 2022 8:25 pm Hi Daniele,
Magnus
Regarding the possible saturation of your images, I think that in the case of flares only a very localized portion of the image will be saturated because flares are usually rather localized in space.
Drizzling is just alignment and stacking on a sub-pixel level. It does not make miracles but if your setup is under-resolved (ie short focal length or large pixels in your sensor) it might help a bit.
Yes, Planetary System Stacker is from the same German guy who wrote Moon Panorama Maker. It gives results similar to other softwares like AutoStakkert or Registax, it is just that I like it more I guess.
I live in Montagnana, a nice town with well-preserved medieval walls close to Padova, Italy ;-) what about you?
Best, Daniele
- Radon86
Hi Daniele,
Thanks for replying to my query about PSS. I have also tried this and had trouble installing it on my windows 10 PC at first. It looks quite good, will experiment with it.
I think I did get some flares, but I was not looking for it so am not sure of the histogram at the time it was captured.
I was just wondering where you were based, nice to know we have an Italian based imager with all your sunny days.
I am in London, where I am lucky to get 12 or more sunny days to properly image (not just a few seconds between clouds).
Magnus
Magnus
