Apollo-M Max mm or the ASi 174 MM
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: Apollo-M Max mm or the ASi 174 MM
Using either of these cameras at f7?
- Been thanked: 2725 times
The answer depends on the Ha filter used. Filter in front position (Coronado, Lunt), rear position (DayStar, SolarSpectrum), internal position (Lunt) ?
- Has thanked: 2924 times
- Been thanked: 424 times
Hi I am looking for a camera to use with a Tilt tuned Lunt 60mm single stacked as well as double stacked with a Lunt 50mm front filter.
Thanks Bill
Thanks Bill
Lunt pressure tuned 60mm
Orion ST 80mm
Bausch and Lomb 90mm
Starfield 2" herschel wedge
various Barlows and Filters
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
Apollo Mini IMX 429m
Apollo -M Max IMX 432m
Sky Watcher SolarQuest
EQ 5 Black
Orion ST 80mm
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
EQ 5 Black
The smaller the pixels the better in this case then Bill
- Has thanked: 1075 times
- Been thanked: 1986 times
Go with this camera:
https://player-one-astronomy.com/produc ... ni-imx429/
or
https://telescopes.net/zwo-asi178mm-mon ... amera.html
Personally, i would say the IMX429 since it's less noisy than the IMX178
or
Thank you Mark and Simon
Orion ST 80mm
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
EQ 5 Black
Orion ST 80mm
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
EQ 5 Black
- Has thanked: 612 times
- Been thanked: 404 times
I keep thinking about either keeping my ASI174 or sell it and buy the Player One camera, but i use that ASI174mm for the moon and it is truly perfect amazing really, and i can use it for planetary also, so i don't want to sacrifice all those only to have a camera for solar mainly and it is normal for other things.
- Has thanked: 9733 times
- Been thanked: 5777 times
- Has thanked: 3060 times
- Been thanked: 2163 times
I would recommend you the Apollo Max (imx432). It is very good for f30+ focal ratios and has around 3-4 times less noise then the 174mm, which helps enormously with seeing.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
