2022-02-23 - AR2954/2955 HA closeup
- JochenM
- Been thanked: 1619 times
A nice blue sky greeted me this morning (long gone in the meanwhile of course), so figured I'd sneak a quick session in. Conditions were surprisingly good (for H-Alpha at least; Continuum and CaK looked like a blurry mush).
AR2954/2955 on the Eastern limb is looking quite nice and active (no surprise given what we've seen the last few days).
Setup:
150mm achromat @ 120mm f/42
Quark Chromosphere
Baader 35nm H-Alpha
ASI174
Thanks for looking!
Setup:
Quark Chromosphere
Baader 35nm H-Alpha
ASI174
Thanks for looking!
- daniele_bonfiglio
- Has thanked: 586 times
- Been thanked: 576 times
Re: 2022-02-23 - AR2954/2955 HA closeup
Wonderful images!
What do you mean by "150mm achromat @ 120mm" ? are you obstructing your 150mm to become a 120mm? why? (sorry for the possibly naive question)
Best, Daniele
Best, Daniele
Solar scopes: Daystar Solar Scout DS 60/930
80mm f6 achromatic refractor with Daystar Quark from the Solar Scout
Scope: Skywatcher Maksutov-Cassegrain 127/1500
Mount: Skywatcher AZ-GTi
Camera: Fujifilm X-T30
Instagram: @daniele.bonfiglio.astropics
- rigel123
- Has thanked: 8189 times
- Been thanked: 8423 times
Excellent shot Jochen!
- Has thanked: 9074 times
- Been thanked: 5977 times
Fabulous pictures Jochen. Good to see you back imaging !
- JochenM
Thanks Daniele.daniele_bonfiglio wrote: ↑Wed Feb 23, 2022 2:48 pm Wonderful images!
Best, Daniele
Not a naive question at all It's pretty much exactly what it sounds like. I used an aperture mask to stop down the opening of the lens to 120mm.
The reasoning behind doing this is essentially catering to the atmospheric conditions in my area. Very simply put, the higher the aperture of the instrument you're using; the more stable your atmospheric conditions (seeing) needs to be to use its full resolution. Conditions here today weren't as such that I would have been able to use the 150mm to its fullest extent; so I opted to stop down to something more reasonable. How much you stop down is always a bit of trial and error; but I've done it enough to usually guess pretty accurately
Hope this helps.
- JochenM
Cheers Warren/Franco.
With winter slowly passing; hopefully there'll be more to come
- Been thanked: 4908 times
Perhaps the best close-up's I've seen for ages Jochen.
Absolutely perfect- showing all the activity around AR2955 and 2954, which can't really be bettered.
15 out of 10 for the effort and results.
Regards
Regards
- JochenM
Cheers Terry, that's quite the compliment there
I've been playing a bit more with the CaK captures in the meanwhile. I managed to turn one into something somewhat decent (not great, but acceptable in my eyes).
Setup:
150mm achromat @ 100mm f15, Baader Blue CCD, Lunt CaK b1800, ASI290
PS: I know the orientation is wrong
Setup:
- daniele_bonfiglio
Hi Jochen, thank you for the explanation! But I still don't fully understand why not just keeping the full aperture. That would not hurt anyway I guess, even if given your seeing the theoretical resolution of your instrument could not be achieved... maybe this has to do also with optical aberrations that will be stronger at full aperture? and so by stopping down you limit those aberrations while not losing in resolution that would be anyway out of reach due to the seeing conditions?JochenM wrote: ↑Wed Feb 23, 2022 3:16 pmThanks Daniele.daniele_bonfiglio wrote: ↑Wed Feb 23, 2022 2:48 pm Wonderful images!
Best, Daniele
Hope this helps.
- Has thanked: 17458 times
- Been thanked: 16550 times
Very nice Jochen! I see a No 2 filament! Keep em' coming. I have missed your images!
- JochenM
Hi Daniele.daniele_bonfiglio wrote: ↑Wed Feb 23, 2022 3:31 pm Hi Jochen, thank you for the explanation! But I still don't fully understand why not just keeping the full aperture. That would not hurt anyway I guess, even if given your seeing the theoretical resolution of your instrument could not be achieved... maybe this has to do also with optical aberrations that will be stronger at full aperture? and so by stopping down you limit those aberrations while not losing in resolution that would be anyway out of reach due to the seeing conditions?
The aberrations in the glass absolutely play a role as well. Although in this case, it wouldn't be too bad in the red end of the spectrum. More towards the blue (CaK imaging for example) would be a different story as these cheap achromats are not all that well corrected there.
It all comes down to optimally sampling for the conditions you're given (or well, getting as close as you can practically get). Have a look at the following thread for a more detailed explanation (and explained much more eloquently than I ever could). The owner of that post also created a little tool to make some quick sampling calculations. I'll attach it to this post.
viewtopic.php?p=279929#p279929
- Angular Resolution, Seeing & Critical Sampling Calculator.xls
- (13 KiB) Downloaded 41 times
Thanks Jochen - regardless of the orientation, that CaK image through your BF1800 shows a lot of fine detail, so you will have some excellent results with that set-up, if not already achieved.
I have the Lunt 60 CaK scope with the BF1200 filter, which can produce some excellent results, but would like the BF1800 too and also for my Lunt 60mm Ha scope too...
- Has thanked: 9243 times
- Been thanked: 5500 times
Hi Jochen,
Well done
Well done
- Albuqshutterbug
- Been thanked: 26 times
Beautiful detail Jochen.
Well done.
Well done.
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
For Imaging:
- Been thanked: 4299 times
Hi Jochen...
Thanks for posting these sharp Ha and CaK images...well done
- JochenM
Hi Jochen,
Well deserved
Well deserved
- DavM
- The Sun?
- Has thanked: 26 times
- Been thanked: 6 times
Great captures Jochen!
Dave
Dave
102mm f11 Fraunhofer achromat refractor - Daystar Quark Chromosphere - ASI 174MM - ASI 426MC
Tilt adapter - Baader CCD Filter Red - 2" interference Filter - Ioptron CEM25p - ZWO EAF focuser
AS3! - Firecapture - Sharpcap - Photoshop CS6 - Lightroom - Affinity photo - Topaz
