From Valery. Kherson, UKRAINE. NEWS
- Been thanked: 2725 times
Re: From Valery. Kherson, UKRAINE. NEWS
Hope you are now getting close to a safe place Valery.
Dear friends,
Unfortunately, we could not drive through the front line. On this day (Thursday), in the selected place, where many refugees crossed the front line, the battles were used using artillery and rockets. Having near the front line for about 6 hours, waiting for permission to cross the front line and without having received it, we were need to return home. All this adventure took about 11 hours.
- Davidm
- Been thanked: 289 times
Sorry to hear you couldn't make it through Valery. Hoping you manage to get safe passage soon.
Lunt LS152T (DSII and CaK module), Coronado Helios 1, Grasshopper 3 2/3" CCD
- Has thanked: 20825 times
- Been thanked: 10498 times
Hope your plans work Valery.
- Has thanked: 17855 times
- Been thanked: 17003 times
Wishing you safe passage in the future.
- Been thanked: 8907 times
Oh dear, I'm so sorry Valery. I can't begin to understand the worry and stress this is causing you. At least you are still safe for the moment. I do hope you can try again and be successful soon
Thanks, friends
We will try to do this Saturday, 23.
- Has thanked: 9327 times
- Been thanked: 6163 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
You are stuck in a nightmare!
I hope luck is on your side for the attempt on Saturday.
All my best wishes, Valery.
Peter
Peter
- Has thanked: 197 times
- Been thanked: 102 times
Like many others I send you my best Valery.
You'll Never Walk Alone.
Stage 2 mod completed @ 100, 127.
Istar 228 arrived, building the frame slowly while learning cnc.
Ditto!!
Not only us here, most of the world walks with you.
Thanks for your support and good wishes, friends!
However, unfortunately, our second attempt has failed. Orks didn't allow to move through the front line.
So many and may childrens were here and they all were need to go back instead of unoccupied territories.
- p_zetner
Dear Valery;
I’m so sad this attempt has failed and so sorry for the fear and disappointment you and your family are enduring.
You seem to be very close to the front lines so maybe things can change rapidly.
I can only hope that some window of opportunity opens soon for you.
Thank you for taking time to share your news and I wish for your continued safety.
Peter
Peter
- Has thanked: 230 times
- Been thanked: 176 times
Valery,
Sending my best wishes to you and your family. Stay safe.
Stephen
Stephen
- Been thanked: 4434 times
So sorry to hear that the plan to get out did not work
Stay safe in the mean time and hope that better circumstances lay ahead.
- Has thanked: 150 times
- Been thanked: 295 times
This is just awful. I was reading that the Russians are not letting food and medicine in and restricting refugees out.
We are with you in spirit.
Dear friends,
In an hour me and my family will go to the front line and try to cross it to get on the un-occupied territory.
I keep my fingers crossed.
Prayers said. .
Are you leaving Ukraine itself or just crossing the line out of Kherson? Either way my thoughts and hopes go with you.
- Been thanked: 4981 times
Stay safe Valery and good luck!
- Been thanked: 4881 times
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Safe crossing Valery!
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 3060 times
- Been thanked: 2163 times
I wish you all the best Valery, be careful with mines on roads.
Prayers it will work.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Good luck Valery, let's hope it is success by evening
Wishing you and your family safe passage to free area.
For now I'd better stay in my country and try to help as much as I can.DeepSolar64 wrote: ↑Fri May 13, 2022 1:59 am Prayers said. .
I will consider to leave Ukraine only in the worst case which, I hope will not realized.
BTW. My 5-th take has failed again. We have reached the front line and then 20-30min later we have heard
a lot of loud explosions - this was our artillery work. So, the corridor wasn't open today and have to go back.
Thanks to all of you who support us.
- Has thanked: 6305 times
- Been thanked: 7327 times
The Ukrainian people’s resolve is high. Russia should remember Afghanistan whose people continued to fight for years after being fully occupied. In part it’s what broke the Soviet Union!!
Stay strong Valery!
James.
Stay strong Valery!
James.
- p_zetner
You know that I wish you success, and soon!
It’s impossible for me to grasp how difficult this is for you, but keep trying and, at some point, you will make it through.
Peter
Peter
- DanielBrousseau
- Been thanked: 139 times
Canadians are at your side Valery, I learned a lot with you for my solar work....
Phantom 140 f/6.5, SW newton 254mm f/5, Quark Chromosphere, Lunt 60mm Universal, Baader ceramic wedge, ASI174 mono, ASI294 mono, ASI290 mono,
Sherbrooke, Québec, Canada
Hello Valery,
Too bad this last attempt was not successful. Keep safe !
- The Sun?
- Been thanked: 7 times
Hi everyone.
As you all know, Kherson is finally liberated. I contacted Valery, and he is safe now. But there are still very serious problems with electricity, mobile communication etc.
With the best wishes, Oleksandr.
